| Together we can score larger rows than we can apart. |
Ok so this is the first year we're using Wind River, after using LabView last year. We have all updates and can connect to the robot. We used an example provided by the FRC, the Simple Robot one i think, and can download it to the robot. But when we reboot the robot with the diver station plugged in we get green lights on 'Communication', 'Code', and 'Stop Button' but cant control the robot with the joystick. If anyone can help we would appreciate it.
cRIO Image: v19 Driver Station: Up to Date Last edited by Caboose : 19-01-2010 at 18:22. |
Re: 2010 Wind River [HELP]
If you are receiving green lights across the board it probably means that it is your code or hardware. Are you loading for release or debug? Also are you clicking the enable tab?(I have to ask) What port does the joystick/gamepad show up on? Are you using Victors or Jaguars?
Silly question: did you click "Enable" on the Driver Station? What does the status message in the bottom left corner of the display say?
Are you downloading the correct executable in Window->Preferences->FIRST Downloader Preferences?
Make sure hardware is set up, for some reason the USB Hub must be plugged into the left side of the Classmate. |
You can use the right one... just have to use the black connector.
For 'Team Number:' we have 587
For 'File to download' we have <our workspace>/SimpleRobot/Debug/<whatevers here.>/SimpleRobot.out I then build the project and click FIRST -> Download We then restart the robot and again get green lights, and yes we do enable the robot... Any ideas? Maybe a step-by-step tutorial? -James |
#7
Another post details the process:
http://usfirst.org/uploadedFiles/Com...ed-Rev-0.7.pdf http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf |
#8
As it always happens we figured it out at the end of the day.
It had nothing to do with Wind River or the computer. What happened was when we were getting the cRIO ready for the move to it's new robot body we unplugged the HUGE cable that goes to the little blue PWM control board and plugged it back into the cRIO in the wrong port ...but we got it working now... finally...![]() |
#9
You can look here for detailed information: http://firstforge.wpi.edu/sf/wiki/do...b/wiki/Loadout |
#11
Q. How many programmers does it take to screw in a light bulb? A. None. Clearly this is a hardware problem. |
#12
| Wind River Cds | Team1710 | C/C++ | 0 | 22-09-2009 10:57 |
| Uninstall Wind River | Lord_Jeremy | C/C++ | 0 | 15-01-2009 15:56 |
| SVN wind river | Mr.Macdonald | C/C++ | 3 | 13-01-2009 12:40 |
| build in wind river | Pneumaticsman | C/C++ | 3 | 12-01-2009 15:54 |
| Wind River Help | BenB | Programming | 3 | 02-01-2009 21:42 |
