Go to Post Is Atlanta an Indian word for "take the longest path between two places"? - Klondike Mike [more]
Unread 18-01-2010, 18:14
ZP8892's Avatar
ZP8892 ZP8892 is offline
FRC #0369
ZP8892 is an unknown quantity at this point
Send a message via AIM to ZP8892
Coding Question
Is it possible to download a 2009 code using the 2010 system? And, if possible, how? Any help would be greatly appreciated.
Unread 18-01-2010, 20:04
Re: Coding Question
A program built using the 2009 libraries will not run on a robot that has been loaded with a 2010 image.
You can probably rebuild your 2009 code using the 2010 libraries and download the resulting program successfully.
Pneumatics coding Nguyen Programming 19 14-02-2008 20:47
C coding ExarKun666 General Forum 12 21-12-2007 14:13
Photoswitch coding magical hands Programming 0 17-01-2006 21:20
coding a potentiometer incognito_NICK Programming 5 14-02-2005 15:56
Coding conventions Anthony Kesich Programming 20 08-01-2004 10:50
