#15
Whats better than pins or keys? Welding of course,
Advantage: Its never going to slip or come apart Disadvantage: Its never going to slip or come apart If you are going to weld, better get it right the first time, we build the pegasus drivetrain first with set screws to try the ratio out then welded everything into place. To mate aluminum to steel we welded a 'yoke' to the shaft and bolted the wheel to the yoke. YOu can also bolt the gears to welded yokes. Keep in mind the yoke will most likely deform under the heat so we turned it back to normal after the welding before bolting the wheels to it. No failures with the same drivetrain for two reigonals and nationals. Keep it in mind as an alternative |
| most important phase? | Jeremy L | Rules/Strategy | 3 | 15-01-2003 15:21 |
| what's your most important drive train advice? | Ken Leung | Technical Discussion | 42 | 07-01-2003 09:58 |
| How important is a machine shop? | archiver | 2001 | 13 | 24-06-2002 04:14 |
| most important charecteristic of successful teams | archiver | 2001 | 11 | 23-06-2002 22:12 |
| Anyway to make it easier for readers to search for important info's? | Ken Leung | CD Forum Support | 10 | 30-06-2001 14:47 |
