Thread Tools |
Rating:
Display Modes |
Re: Hybrid Kicker
I've been trying to make a similar locking mechanism. Would you mind getting close up pics of that or just explaining your locking/release method?
Thanks. Looks great. ![]() |
Re: Hybrid Kicker
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 A small pneumatic cylinder should be able to release it. |
Re: Hybrid Kicker
Re: Hybrid Kicker
We found that a gate latch was fine, but removing some material from the inside radius of the very tip of the release latch helped it release more smoothly.
I noticed from the video that many of the balls did not go in, either bouncing too high or not rolling up the goal ramp. I attribute much of that to the lack of carpet, but I'm wondering if you also noticed that and, if so, did anything to address it? Thank you for posting that video, it helps us confirm that we're on the right track. Now for a decent ball control mechanism... |
Re: Hybrid Kicker
Re: Hybrid Kicker
Nice hybrid design - I like it.
Have you given any thought as to how you will be mounting it (if you go with this design) and also allow for decent ground clearance (if you plan to go over the bump)? Also, do you think you will need an on-board air compressor or just some pre-filled air tanks? |
#7
Re: Hybrid Kicker
We will have a compressor, and four clippards We plan on having kickers on all sides of the bot full length of each side |
#8
Re: Hybrid Kicker
For quick release under load I like the water ski qiuck releases. The fence latch could be modified with a ball bearing on the contact to work in similar way.
#9
Re: Hybrid Kicker
We've been playing with a similar kicker but we can't seem to get our piston to fire as quickly as yours does.
If I'm understanding your mechanism correctly, the retracts the kicker to the locking mechanism and then to shoot the piston is "Fired" and then allowed to charge before the locking mechanism is released? I'm sorry if this is a dumb question but it's something we've been struggling with... |
#10
Re: Hybrid Kicker
The latch is then released. However I believe there are some very serious saftey issues coming into play here. Precharging a cylinder and using elastic bands to increase the kicker velocity puts the cylinder well outside its normal operating velocity. From other posts it appears that the cylinders will degrade and become dangers if piston is moving at speeds around 20 in/sec. From the video I can't determine the velocity of the piston, but it appears to be moving extremely fast. Because a damaged cylinder could kill someone I highly recommend that you determine the piston velocity and if it is even 15in/sec reevaluate your kicker. |
#11
Re: Hybrid Kicker
The safety precautions Matt suggests are very important, not only for this type of kicker, but any kicker that has a lot of final velocity (basically any kicker than can get the ball to fly downfield).
The part that contacts the ball will be moving very fast, it needs to be very solidly attached. |
#12
Re: Hybrid Kicker
Also I believe this is the type of quick release which was discussed earlier.
http://www.defender.com/product2.jsp?path=-1|619045|619408|966099&id=195419 |
#13
Re: Hybrid Kicker
Thanks for the explanation. I'll have to look into the final velocity that our piston will travel at. I also saw some of the posts speaking of the dangers of having pistons move around 20in/sec... |
#14
Re: Hybrid Kicker
Can you post a picture or something of a water ski quick release?
#15
Re: Hybrid Kicker
yes pleez do
| #1860 kicker prototype | sloteera | General Forum | 12 | 04-02-2010 14:27 |
| 987 Kicker Destruction | JM987 | General Forum | 29 | 23-01-2010 16:46 |
| FRC114 Kicker Teaser | James114 | Robot Showcase | 10 | 22-01-2010 16:56 |
| kicker or linear accelerator? | John G | Technical Discussion | 7 | 20-01-2010 13:48 |
| Video of Kicker Prototypes | falconmaster | General Forum | 52 | 18-01-2010 22:43 |
