Go to Post -Best FIRST Robot: One that Makes it to Competition - Conor Ryan [more]
Unread 18-01-2010, 21:57
Faldor Faldor is offline
New Guy!
AKA: Jake Sinclair
Team Role: Photography
Faldor is an unknown quantity at this point
Send a message via MSN to Faldor
Gyro/Acceler. connections
Hello, can any body tell me what we would connect the gyro/accelerometer to?
Thanks
EDIT: oh and the wires too, please?
Unread 18-01-2010, 22:00
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: Gyro/Acceler. connections
They connect to the analog module on the cRio. Once connected you can use the built in support to draw meaningful values from the two included sensors. http://usfirst.org/uploadedFiles/Com...ual%20RevA.doc is the link to the manual on the included sensors. Hope this helps.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 18-01-2010, 22:02
viper110110 viper110110 is offline
FRC #1325
viper110110 has a spectacular aura aboutviper110110 has a spectacular aura aboutviper110110 has a spectacular aura about
I think the accelerometer connects to the digital sidecar, but the gyro definitely connects to the analog module
Unread 18-01-2010, 22:12
New Guy!
AKA: Jake Sinclair
Thank you both you guys have helped
http://uguf.proboards.com/
Unread 18-01-2010, 22:34
WGRAY WGRAY is offline
FRC #2027
WGRAY is an unknown quantity at this point
You can check Labview Gyro example for a wiring diagram, however it is not available for the accelerometer vi even though they do have a specific vi for the ADXL345 12C, Maybe if enough people request it labview engineers will supply it.
Unread 19-01-2010, 04:36
Boiler Up
AKA: John Downey
viper110110 is right I hadn't read the accelerometer part of the sensor guide yet, this years gyro is an I2C/SPI gyro so it would connect to the digital sidecar.
John Downey
Unread 19-01-2010, 04:41
New Guy!
AKA: Jake Sinclair
Thank you jt, but could you also tell me what cables i would be using, and exactly where on the digital sidecar, or the analogue module it would connect?
Thanks again
Unread 19-01-2010, 07:06
Read the Sensor Manual. It should give you lots of answers, but if you still have questions afterward, go ahead and ask them.
Unread 19-01-2010, 21:42
New Guy!
AKA: Jake Sinclair
I am still having issues as to where exactly on the digital sidecar they connect. So if anyone can help much appreciated.
Unread 20-01-2010, 01:38
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I2C is easiest. You can just hook the 4 I2C wires to the digital sidecar's I2C pins.
Unread 20-01-2010, 01:57
New Guy!
AKA: Jake Sinclair
thank you very much, you have helped me muchley
Kudos to you!
Unread 20-01-2010, 15:52
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
can anyone tell me where exactly the accelerometer connects to the cRIO or the analog breakout? and does anyone have any schematics?
Unread 20-01-2010, 18:59
No, because it connects to neither.
As Joe Hershberger posted not very long ago, the easiest way to connect the accelerometer is to use the four I2C pins on the board. They connect directly to the four I2C pins on the Digital Sidecar.
Unread 20-01-2010, 20:11
fiferdc fiferdc is offline
AKA: David Fifer
FRC #1747 (Harrison Boiler Robotics)
fiferdc is an unknown quantity at this point
The gyro has a three pin connection (ground, power, signal), so how would it connect to the I2C, which has four connections? Connecting it to a digital I/O port also seems odd because you don't want a reading of either 1 or 0 for a heading. Team 3176 is still trying to get their gyro up and working. We have it connected to the analog breakout, but we're having problems getting a reading, so I'm not sure if that is due to a bad connection, or just a programming problem.
Unread 20-01-2010, 20:48
I2C is a serial bus, so you send and receive messages that contain multiple bits, giving you the range and resolution you need for the accelerometer.
Jumper Connections Lord Byron Electrical 4 26-01-2009 20:43
Field Connections? xxMORT11xx FRC Control System 4 24-01-2009 21:51
Connections to Driver Station Zellboy Electrical 1 23-01-2009 16:24
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
Drill Motor Connections archiver 2001 8 24-06-2002 00:49
