Go to Post Driving and using the cell phone and taking a picture with it. Where is your Safety Captain? - GaryVoshol [more]
  #91   Spotlight this post!
Unread 18-01-2010, 12:36
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Wink Re: The ultimate game breaker bot.
I actually have found the ultimate bot design. The issue is whether or not any rules will be broken.
http://www.xkcd.com/689/
We do not stop playing because we grow old;
we grow old because we stop playing.
  #92   Spotlight this post!
Unread 18-01-2010, 12:49
Racer26 Racer26 is offline
heh... If only Randall had named that comic Dozer's Revenge
  #93   Spotlight this post!
Unread 18-01-2010, 16:44
KGood's Avatar
KGood KGood is offline
Capt'n
AKA: Kevin
FRC #2134 (Aztec Pirates)
KGood is an unknown quantity at this point
To start, this would most likely be barred from use simply because it's designed as a loophole tactic; judges try to eliminate that as much as possible because it's not in the spirit of the game.
Also, wouldn't this violate the finale configuration rule <R10> which says the maximum "regular configuration height" is 60 inches, meaning the robot can't extent to the height you specified because the bar is 7 feet above the ground?
Also, I can't cite the rule off hand but robots can't interfere with the ball-return mechanism...I'm fairly sure the judges could use this to disqualify your bot in attempt to keep out loophole designs, like I said in the beginning.
2007: Rookie All-Star Award
2008: #2 of 54 in AZ Regional
  #94   Spotlight this post!
Unread 18-01-2010, 16:47
<G30> and the OTHER configuration in <R10> allow it. <G47> only disallows contact with a ball on the return. The second it is not on the return, a ball can be contacted.
  #95   Spotlight this post!
Unread 18-01-2010, 16:57
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Judges are there to enforce the rules, not bar something because it is a 'loophole' tactic. It's up to the GDC to determine legality of a tactic/device.
When you are touching the tower you may assume FINALE configuration at any time. Thus the total allowable height while in contact with the tower is 90"
The tactic here does not interfere with the return mechanism. It waits for the ball to leave the return mechanism and then redirects the ball.
From what I see, properly implemented, it could be legal. As for it's effectiveness ... That is to be seen. I, personally, look forward to playing against this strategy.
___________________
- Tennyson, Ulysses
  #96   Spotlight this post!
Unread 18-01-2010, 20:30
Mike9966's Avatar
Mike9966 Mike9966 is offline
Mentor Mike
FRC #2846 (Fire Bears)
Mike9966 is an unknown quantity at this point
So, how about if a bot has a net that sticks up 3-4 feet and when the balls leave the chute they hit the properly placed bot and at least roll toward the tunnel into their alliances side?
It's passive, but if it's in the middle of the bot the balls would hit it more than 3 inches in the frame perimitter.
I don't see this as a sole stragity, but as something availble to help the alliance if needed.
What do you think?
Mike
Do the best you can! Always
Go FireBears
2009 10000 Lakes Finalists, thanks 2825 & 2177
2010 10000 Lakes quarter finalists
2011 Duluth and 10000 Lakes
2012 Superior, and 10K Lakes, Qt finals, MRI
2013 Northern lights, 10K Lakes-Semi finalists, MRI, River Rendezvous, Minne Mini
2014 Northern Lights, 10K Lakes
  #97   Spotlight this post!
Unread 18-01-2010, 20:35
Zack247's Avatar
Zack247 Zack247 is offline
AKA: Zack Medow
FRC #0247 (Da Bears)
Zack247 is a name known to allZack247 is a name known to allZack247 is a name known to allZack247 is a name known to allZack247 is a name known to allZack247 is a name known to all
You can't touch the balls once you're up on the tower.
  #98   Spotlight this post!
Unread 18-01-2010, 21:09
Chris is me's Avatar
AKA: Pinecone
Says who? Which rule prohibits this?
  #99   Spotlight this post!
Unread 18-01-2010, 23:18
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I think the only question here is, The GDC want's teams to play soccer, more or less, is doing something other then playing soccer going end up becoming illegal via a clarification week 6 or between events? Basically, teams are scared of ending up like 190/1519 in 2008.
  #100   Spotlight this post!
Unread 19-01-2010, 01:13
AKA: Pinecone
The GDC has surely seen this thread, and posted Team Updates about above bumper zone passive ball manipulation mechanisms in response to proposals much like this one.
Multiple aspects of 190's hurdling approach were deemed either illegal or against the intent of a hurdle only a week or so into build season. 1519 is sketchier territory.
I don't think a lot of teams are scared of their robot designs being ruled illegal.
  #101   Spotlight this post!
Unread 19-01-2010, 08:30
Carol's Avatar
Carol Carol is offline
FRC #0365 (MOE)
Carol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond repute
Originally Posted by Daniel_LaFleur View Post
Judges are there to enforce the rules...
Not to pick on Dan, but I want to clarify the roles. Judges are there to select awards (Chairmans, etc.) Referees and Inspectors are there to enforce the rules. Very different roles among the three positions.
MOE 2007 Chairman's Video by MOE video team and Paul Lazarus http://moe365.org/CHMN_AWD_video_2008.php
MOE 10-Year Video Celebration on YouTube http://www.youtube.com/watch?v=ETcSMUBUqEs
  #102   Spotlight this post!
Unread 19-01-2010, 08:37
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I stand corrected.
___________________
- Tennyson, Ulysses
  #103   Spotlight this post!
Unread 19-01-2010, 09:26
IMO, 190's hurdler, while certainly playing the edge of the rules, I think should have been allowed. As for 1519, I don't see how it was sketchy at all. They had a movable control board, which was the ROBOT, since it had the ROBOT CONTROLLER on it. Fezzik and Speed Racer were simply two MECHANISMS it could be attached to. I always thought this sort of thing was EXACTLY within the spirit of the interchangeable MECHANISMS but have to be within 120lbs all inclusive rule.
In any case, I dont think that theres going to be many (if any) teams trying this tactic, as its very difficult to do it within the rules as written now.
  #104   Spotlight this post!
Unread 19-01-2010, 11:37
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
Last time I played soccer, which was quite a few years ago granted, I could "trap" the ball with my chest and drop it at my feet to dribble down the field. All I see this approach doing is the same thing.
You obviously can't POSSESS the balls over the bumper (using your hands in soccer) but I see nothing in the rules, now that they clarified them with the update that would disallow passively directing the ball with the top of your robot (your chest) like you do in soccer.
  #105   Spotlight this post!
Unread 19-01-2010, 12:58
If you wanted to go by the spirit of the rules, 1519 was not legal. If you wanted to go by the letter of the rules, then they were (unless possibly their bumpers weren't). (To quote a Q&A for that year responding to a question about something else, "That would be a violation of the spirit, but not necessarily the letter, of the rules.") ROBOT that year was poorly defined; something about whatever a team places on the field that has passed inspection, if I recall correctly.
The next year, the definition of ROBOT was changed to include a mobility system, control system, etc. and it hasn't changed.
Anyone up for a little game of ultimate frisbee? #2970-Dan Championship Event 17 13-04-2009 10:31
FIRST Game Survivor: Tie-Breaker Justin Montois Games/Trivia 0 19-03-2009 13:20
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
pic: Ultimate 4 Square Field (Vex Game) Alex Cormier Extra Discussion 11 04-07-2007 14:12
The Ultimate Showdown of Ultimate FIRSTiny Billfred Chit-Chat 4 12-04-2006 22:43
