Go to Post ahhhh, for the good old days, when our robots always seemed to come in well under weight instead of well over... :( . - dlavery [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 19-01-2010, 04:43
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
We need bolts!!!
We're in Australia and its fairly hard to get any imperial parts. Currently, we are trying to find the bolts, nuts, and washers that we need to mount components on our electrical board. Do you have any suggestions? We have looked in the KoP, but we don't see any of the screws that we need, however some of our parts have not arrived yet, so we are not certain. For you teams who have your KoP, can you help?
Thanks,
timytamy
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 19-01-2010, 06:01
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: We need bolts!!!
Mounting hardware for most of the electronic components is not included in the KOP.
It may not be necessary to find the imperial hardware for mounting the electronics, you may find that the closest fitting metric hardware works just fine.
Power Distribution Board: 1/4" or M6
Analog Breakout: Hardware included in KOP to mount to cRIO
Digital Sidecar: #8 or M4
cRIO: #10 or M4
Jaguar: #8 or M4
Unread 19-01-2010, 08:19
timytamy,
We use tywraps to hold down our electronics. They are easy to cut when you need to replace or move something and they are not conductive. If you drop one into the robot, it won't kill anything like a dropped screw.
Unread 19-01-2010, 09:45
Racer26 Racer26 is offline
+1 to Al's point. 1075 has done the same.
Unread 19-01-2010, 09:51
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
+2 571 also uses zip ties
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I was on a UK team last year, and we had the same problem. We ended up mail ordering from RS (similar to MSC) and other online/catalouge vendors.
Wetzel
Viva Olancho!
Unread 19-01-2010, 09:54
wilmo's Avatar
wilmo wilmo is offline
FRC #0868 (TechHOUNDS)
wilmo will become famous soon enough
Zip-ties for the win!
Nuts n' Bolts Podcast (NEW!) Arkorobotics Chit-Chat 3 10-05-2006 16:24
80/20 t-bolts/nuts? Henry Anthony Inventor 6 16-02-2006 07:13
U-bolts archiver 2001 2 23-06-2002 23:43
U bolts archiver 2001 3 23-06-2002 23:34
Screws, Nuts and Bolts.... archiver 2001 10 23-06-2002 23:32
