Go to Post And then I learned how to use the lathe...long story short, I ditched my plans to become a music major and became an engineering student. - Karibou [more]
Unread 17-01-2010, 15:51
frenchie4111 frenchie4111 is offline
None #1111
frenchie4111 is an unknown quantity at this point
Problem Switching Between Modes | Powerhawks Team 1111
Hello, this is Michael from the GS IPT South River Powerhawks Team 1111,
We have gone through the second section of the manual completely and have been successful in uploading and running code (C++) to the cRIO. However, in order to run the code we must stay in teleoperated because when we switch to autonomous mode it runs the autonomous code correctly but does not allow us to switch back to teleoperated.
tl;dr After switching to autonomous we can't switch back (we select teleoperated but autonomous code continues to run).
Thanks.
Unread 17-01-2010, 16:00
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Problem Switching Between Modes | Powerhawks Team 1111
the problem: infinite loops
make sure you have a IsAutonomous check instead of an infinite loop. When you switch to Telop/Auto, The DS informs the cRIO that the state has changed, and you need to manually poll for this info
Watchdog.Kill();
Unread 18-01-2010, 19:48
None #1111
Thanks byteit for the quick reply, but the code we have loaded on the cRIO at this time is the default (C++) code and it does not contain any infinate loops.
Unread 19-01-2010, 06:57
Diserasta Diserasta is offline
4 Hours of sleep a day on avg.
AKA: Samouil
FRC #3132 (Thunder Down Under)
Diserasta is an unknown quantity at this point
Doesn't the default code for the autonomous mode use a jumper to decide whether it's in autonomous or not. You could just change that so that when autonomous finishes running (or a set a timer for 15 seconds) it switches to teleop.
Hope this helps.
In .h
RobotDrive *ted;
RobotDrive *tedDrive;
In .cpp
DriveTrain::DriveTrain (RobotDrive *ted){
tedDrive = &*ted;
Yo dawg, I heard you like pointers, so I put a pointer in yo pointer, so you can de-reference your pointer while you point to yo pointer.
Unread 19-01-2010, 08:44
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Are you using the IterativeRobot class? If so, make sure to be using the correct function.
Switching between Autonomous and Teleoperated Technic-R-C National Instruments LabVIEW and Data Acquisition 3 07-02-2009 08:55
Toggling between modes csshakka NI LabVIEW 3 02-02-2009 20:47
Switching between Hybrid and User-Controlled Zyklon Programming 3 13-02-2008 08:30
Question about switching autonomous modes DemonYawgmoth Programming 2 23-03-2005 17:02
switching modes Allison Programming 8 06-04-2004 13:37
