Go to Post Automonous - n. the frequent sound made by a team member not wearing a watch. ex: Do you know automonous? - Cynette [more]
  #41   Spotlight this post!
Unread 19-01-2010, 07:47
Re: Serial to CAN Gateway in new Black Jaguars?
Kevin,
The Jaguar controls average current by pulse width modulation but the pulses can only go between 0 volts and the battery terminal voltage (12 volts nominal.). Are you thinking of current sense? That is available through the CAN bus. There is a series resistor built into the Jaguar and the voltage drop across that resistor can then be used to calculate current through the device.
Where can we get PS2 type game controllers with serial ports? waialua359 Control System 12 25-01-2006 22:33
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
VXML Gateway to Web Databases Adrian Wong Rules/Strategy 11 08-10-2001 08:10
