Go to Post It will mean far more than you can imagine...and really, you can't lose. - David Kelso [more]
Unread 19-01-2010, 08:47
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Question Mecanum wheels - bearings?
Looking at the 8" Mecanum wheels that AndyMark sells, it appears the side plates on the wheels have a 1.125" hole cut out to install bearings. My quick question is: when we press the bearings in there, what's to stop them from being pressed in too far and ending up inside the wheel? As I recall, the KOP wheels have a small lip on the inside to prevent the bearings from going in too far.
Am I over-thinking this? We've never worked with Mecanum wheels, and I'm a little nervous trying to make sure we have all of our ducks in order before we order them.
Unread 19-01-2010, 08:52
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Mecanum wheels - bearings?
Depending on your axle size. you can either go with:
http://andymark.biz/am-0028.html
or
http://andymark.biz/am-0030.html
They are flanged bearings. You then mount your sprocket/gearbox against on the side with the flange to hold them in.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 19-01-2010, 12:24
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Talking Re: Mecanum wheels - bearings?
Thanks Jimmy!
Chief Delphi and AndyMark are always one step ahead! Excellent!
Funny side note: my cousin Erin graduated from Lakota East in... let me say 1995 or so. At the time, they lived in West Chester.
Stop by 2656 and see if the Mecanum wheels worked out when you're in Pittsburgh!
Unread 19-01-2010, 12:53
Mentor,QCR Planning
Not a problem.
Small world! If your cousin is local, they can stop in anytime.
I'll have to remember to do that. Our pits are always open to guests as well.
Unread 19-01-2010, 13:13
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
The first one you linked to won't work, the OD is not the correct size. The FR6ZZ is a 0.875OD.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 20-01-2010, 08:29
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
James- does this mean that these Mecanum's will require a 1/2" axle? If so, I guess we can just bore the bolt holes out
Unread 20-01-2010, 09:00
Mentor,QCR Planning
Here is the correct link.
http://andymark.biz/am-0209.html
Unread 20-01-2010, 09:53
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Question Re: Mecanum wheels - bearings?
I saw those yesterday. They lead back to my original question, of whether or not they will "fall in" inside the wheel without a flange/edge. ie: what's to stop us from pushing them in too far?
Unread 20-01-2010, 10:01
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
you could cut up some spacers for the inside to stop them from going to far. thats what im going to work on today so we dont need to order more bearings.
Unread 20-01-2010, 10:47
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
We cut out the hubs to last years wheels and placed them inside the Mech wheels (we did need a small spacer) and used the kit bearings. We saved $$$$.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 20-01-2010, 12:22
Mentor,QCR Planning
Bearings from Andymark are $5 each, which is cheaper than other places.
The time and effort hours it saves, that can be put towards kicking, elevating, or suspending are priceless. My opinion.
Unread 20-01-2010, 12:45
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Third time's a charm... here's a 3/8" ID, 1-1/8" OD, with a flange:
http://andymark.biz/am-0573.html
(FYI, these were linked from the same page where you'd buy the wheels: http://andymark.biz/mecanum8.html)
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 20-01-2010, 13:15
Hmm, those look new. I noticed them on the AM website this morning.
Two years back, the 1/2" bearing was what we were forced to use and we had to bore out the (IFI) chassis to do so.
What you might consider is using hubs and having a live axle directly off the gearbox.
James Tonthat
Unread 20-01-2010, 14:57
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Good idea. I'll have to remember that.
Since Mech wheels need 4 transmissions, we planned on using the AndyMark Hubs and direct drive to save the weight of the chain.
Unread 20-01-2010, 17:05
joeweber's Avatar
Coach team 1322
That will leave you 6 to 7 inches between the motors. Real tight for a kicker. We did it, it is more complex than it looks. Installing bearings on the mechs with a sprocket is a simple operation.
Mecanum wheels akash155 General Forum 12 20-02-2007 22:15
Has anyone keyed IFI wheels instead of using the bearings? Dasistmeinmoped Technical Discussion 3 24-01-2007 00:03
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
