Go to Post You don't have to build a winning robot to build a team, but you won't build a great team unless they are striving to build a winning robot. - Richard Wallace [more]
Unread 19-01-2010, 09:34
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
pic: 2010 Lake-Coast drive
Unread 19-01-2010, 09:35
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: 2010 Lake-Coast drive
I am curious - what made you decide to build such a small chassis? (looks to be no more than 22" long, and ~20" wide).
Unread 19-01-2010, 09:42
James1902's Avatar
James1902 James1902 is offline
Chopsaw??
FRC #1902 (Exploding Bacon)
Team Role: Marketing
James1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond repute
Hmmm...It looks like Florida will have at least one tunnel traveler. Looks good guys, can't wait to see the rest
-In case of major discrepancies it's reality that's got it wrong
-oink oink boooooooooooooooooooooooooom
-Iz it can b pig go boom time now plz?...kthanxbye!!
Unread 19-01-2010, 09:48
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Are you only going to be powering 1 wheel per side or have not run the chain for the rest?
Unread 19-01-2010, 10:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Look close, you can see sprockets on the outside of the end wheels, which will likely be used to connect them together with a long chain.
6 wheel robots usually work better with all 6 wheels powered, though.
Unread 19-01-2010, 10:42
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
I'm more interested in the contraption behind the table. Care to describe it?
Hi!
Unread 19-01-2010, 10:47
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Now that you said that I see them (iPhones need larger screens lol). Now it looks like the 4 corners are powered and the middle wheel that is an 1/8 lower is not. Is this correct?
Unread 19-01-2010, 11:01
MrForbes's Avatar
AKA: Jim
Looking further....it appears the center wheels will be driven directly off the toughboxes, from the other of the double sprockets. Neat design.
Unread 19-01-2010, 11:46
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
That square looks just like mine, rust and all. I'm gonna have to check my garage and see if it's still there!
Unread 19-01-2010, 11:52
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I know this isnt the finished chassis but I would seriously consider beefing up the rear part of the frame where you have the cutouts. By removing the legs of the channel it will want to bend at that point. Perhaps look at putting a belly pan underneath the entire chassis out of 1/4" baltic birch.
Mentor 2415
Unread 19-01-2010, 13:25
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Or since the chassis is rather short, just patch on an 1/8" doubler plate to the outside of the chassis around where the cutout is. My bigger concern is that they appear to be sharp corners and not radius cuts. Sharp corners will be a potential source of failure in the part.
Unread 19-01-2010, 21:43
gorrilla's Avatar
AKA: adam spears
It is 26x19" we made it small so it would be more annoying to other robots
[quote=squirrel;902171]Look close, you can see sprockets on the outside of the end wheels, which will likely be used to connect them together with a long chain.
all six wheels will be powered, we just did not have the sprockets in stock at the time lol
its our mascot Volty Mcnut
you are correct sir.
we just bolted a 1/8th alluminum plate to the bottom, we also will have a super-structure to tie everything together, and it will also be completely welded*
not only will it go under the tunnel, but it Will climb the bump
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 16-02-2010, 11:54
Techie590's Avatar
Techie590 Techie590 is offline
AKA: Mike Jorgensen
FRC #1504 (Desperate Penguins)
Techie590 is an unknown quantity at this point
how do you plan on meeting the bumper clearance height
West coast drive (6wheel) question Bruceb Technical Discussion 9 09-01-2010 09:34
New Bumper Rule makes West Coast drive Illegal? Alan Ing Technical Discussion 24 30-01-2009 10:16
pic: West Coast Drive: Spokane Style CraigHickman Extra Discussion 31 14-12-2008 20:02
Space Ghost Coast to Coast to DVD Nov 18th!! D.J. Fluck Chit-Chat 7 07-11-2003 18:57
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
