Go to Post Imagination is important, but try not to use it as a substitute for actual information. - Alan Anderson [more]
Unread 18-01-2010, 23:22
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Jaguar brake while disabled
We have found that we need our robot to slow down much faster when disabled than it currently does.
Therefore, I hope the Jaguar's (we are currently using Victors) brake feature will help us. However, I'm not sure if it has any effect when the robot is disabled; I suspect it doesn't.
Does it have an effect when the robot is disabled, or does the Jaguar shut down its output completely and do no electromagnetic braking?
Thank you for any help.
Unread 19-01-2010, 08:11
Re: Jaguar brake while disabled
It is my understanding that the brake function is engaged whenever the controller receives a zero speed command either from the throttle or from disable. One must ask the question as to what are you expecting the brake to do for you? The brake function is a dynamic electrical operation. It merely puts a short across the motor such that motion is turned into heat through the back driving of the motor. The faster the motor is spinning, the more current is turned into heat. If the motor is not turning, no current is developed and the brake does nothing.
Unread 19-01-2010, 10:00
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
It definately does still activate the brakes when disabled.
I noticed it alot last year when pushing around the robot. It slid sideways easier than it did forward and back.
Unread 19-01-2010, 10:05
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
I believe there are two settings on the Jaguars. You can either set it to coast or not. If I remember correctly, if you put it to coast, when you give it a "0" it won't lock the wheels, but if you set the jumper so that it doesn't coast, then it locks the wheels, much like what you are observing.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 19-01-2010, 17:54
AKA Ryan Van Why
FRC #0957 (SWARM)
Great, that removes the complexity of adding a new switch and changing the programming. Hopefully, they'll be more effective at stopping the robot (with the Victors, it can take 15 feet to bring it to a stop, but with full reverse (done manually,) it can stop in 1.5 feet )
Thank you for your help.
Stay in "Search-Begin" while disabled? billbo911 NI LabVIEW 1 17-02-2009 16:32
jaguar brake\coast controlling 2roy999 Electrical 6 01-02-2009 16:34
Victor brake feature Japper Control System 3 04-02-2008 10:39
HELP NEEDED! Camera twitches while disabled lkdjm Programming 5 19-02-2007 11:34
Brake/Coast Jumper archiver 2001 3 24-06-2002 01:04
