Go to Post Hey, I'm not my dad, I dont know anything! - Lil' Lavery [more]
Unread 19-01-2010, 00:23
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
How do those winch-loaded shooters work?
So I have seen some shooters from overdrive that work by winding a cord around an axle to draw back a spring or tubing. Then they lock in place via many different methods (locking pin, winch, ect.)
My question comes about the release. When you release the mecanism, does it unwind the motor? Or, is there some sort of clutch mechanism that lets it slip so that you don't lose force from winding the motor? If so, what is it?
Thanks in advance.
Unread 19-01-2010, 00:32
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: How do those winch-loaded shooters work?
As in most FRC designs, a plethora of mechanisms are used by teams. In most successful cases, the motor is not moved during a release. My team used a dog gear system to disengage from the gearbox in 08, similar to the AndyMark shifters. I would recommend taking a look at some drawings on AndyMark.biz and figuring them out.
I have also seen gate hinges and... a hood latch... used to release cables with varying success (usually good if you don't dip 'em in paint )
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 19-01-2010, 00:36
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
There is a clutch mechanism that does release the winch without "rewinding" the motor. A good thread to see for this is this one http://www.chiefdelphi.com/forums/sh...threadid=80278. If the super shifter/ dog gear isn't your thing check out this page on mcmaster http://www.mcmaster.com/#6283k24/=5fr67j for some inspiration.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 19-01-2010, 01:11
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
At the $350 price for the super shifters, they are pretty out of our league.
I am opting towards the rachet type things however, could someone show me an example of how to disengage the pawl?
I'm not really sure how I could setup a rachet and pawl so that it wouldn't want to unwind the motor as my cable unwinds.
Care to elaborate? I was trying to think of a realworld machine that uses something like this, but I have come up with nothing.
Unread 19-01-2010, 01:18
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
I'd think a simple servo with its output linked to the pawl could work rather well as a disengaging mechanism. Also theres always the option of a small pneumatic cylinder, but i'd figure that'd be overkill.
Heres a simple paint drawing to help illustrate (literally) my idea
Unread 19-01-2010, 10:12
Racer26 Racer26 is offline
For the 2008 offseason we modified our robot to have a launcher mechanism based on 1114's wildly successful Simbot SS. We loaded it with a dog gear transmission (a modified AndyMark Gen 2 shifter, i believe) with one of the sets of gears removed. I forget how we stopped the spring pressure from backwinding the whole rig. I think we had a pneumatic ram that locked it in place.
Unread 19-01-2010, 11:16
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
I have been thinking all morning on this.
I still can't figure this out:
I can pull the cable back with a winch and it won't back drive. But when I release the winch the motor will want to spin with the springs.
What I think I need to find is some sort of clutch between the cable and the winch. Any suggestions?
Unread 19-01-2010, 11:21
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
We ran our Overdrive shooter with just one motor and no other actuation. Able to reload in approx 1.5 seconds, if I recall correctly (with a whole lot more stress on it than this year requires).
Here's a pic of it engaged and ready to fire:
http://www.chiefdelphi.com/media/photos/31538
Here's a pic of it unloaded:
http://www.chiefdelphi.com/media/photos/31539
Extremely efficient and simple, just have to grasp the concept. Feel free to ask any other questions.
Unread 19-01-2010, 11:51
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
This is I think the 3rd time I have tried to figure out that linkage, and it clicked, I get it, and realize how simple it really is. It does require a non-backdriveable transmission though, correct?
Thanks alot, It is likely we will use something like this.
Unread 19-01-2010, 11:59
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
While a non-backdrivable transmission will do the trick, it can be done without. If you consider how the linkages work, when the main sprocket is at the "ready to fire" position, there is very little force driving the sprocket either forward or backward. If you use a position sensor that can stop the sprocket at this "ready" location, the sprocket won't move until you say "fire!" and push it just past this point.
"It's NOT Just A Robot Thing!"
Unread 19-01-2010, 12:16
Aren_Hill's Avatar
Build Nifty Things
Yes it does, we acquired this trait in the form of a Dewalt XRP gearbox with a FP driving it (which also gave us a vital speed reduction).
Other options include worms gears, or a one way ratchet system (one of the easier ways, think box end ratchet wrench and a hex on the shaft)
I say it requires it for general safety, we always had the "ready to fire" position far enough away from tripped to prevent accidental firing from sharp contacts or such.
A guy who likes robots.
Unread 19-01-2010, 12:26
Brandon Holley's Avatar
In 2008 we made a "catapult" of sorts to shoot the ball. Here is a picture from the arizona regional of a ball in mid air off of one of our shots(http://www.chiefdelphi.com/media/photos/30965). From our estimates we were winching back around 300lbs of spring force.
Our initial solution was one of the andymark dog gears that everyone here has mentioned thus far. We ran into a problem however when the winch was fully cranked back. There was so much tension in the springs that the dog gear would not disengage. We were using a 1.5" bore, 1" stroke, pneumatic piston to disengage.
We went back to the drawing board and decided to use a ball lock clutch. If you do some searches here on CD for ball lock transmissions you will see that team 222 has quite a bit of experience with them. Essentially how they work is you have a hollow shaft which a gear sits on. The gear has slits cut into it so if you looked at it from the side you would see something like a + sign. The hollow shaft has spots for 4 ball bearings to sit in, so that when they are placed in the shaft, the gear spins freely around the ball bearings. You then actuate a rod inside of the hollow shaft so when the rod pushes through the shaft, it forces the ball bearings into the slots cut in the gear.
This was a very effective system for us, and will be something we use again if we ever have to winch something back and then unload it quickly.
-Brando
PS- obviously if you have any questions feel free to ask
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 19-01-2010, 12:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We are thinking about making a winch spool that has two pins sticking out one end, and a pin going thru the motor driven shaft that will engage them. The spool will slide sideways on the motor shaft (driven by a fork in a collar, powered by a small pneumatic cylinder) to disengage the spool from the shaft.
We haven't built it yet, so don't expect it to work...but it looks like something we can make without too much trouble.
Unread 19-01-2010, 12:34
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
I don't see what a CIM motor can't be engaged and the motor controller switched to Coast while shooting. You would be rotating through a angle of less than (180 degrees * Gear Ratio). The motor will not spin faster than the ~5500 rpm it is rated for and the power generated seems negligible. What else makes these motor attached designs less successful?
Thanks!
Unread 19-01-2010, 12:39
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Thanks!
Drag. Especially through a gearbox.
___________________
- Tennyson, Ulysses
Ultrasonics: Will it work and how to make it work DavidB Electrical 2 17-01-2009 16:27
How do the Shooters work? Akash Rastogi Technical Discussion 31 06-04-2008 03:10
Linear Shooters - How did you do it? Leav Technical Discussion 19 10-03-2008 17:20
How many shooters do we have??? Kevin_547 Scouting 18 20-02-2006 11:05
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
