Go to Post All labor is donated by the webmaster "Brandon". - Mike Martus [more]
Unread 18-01-2010, 22:30
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Hybrid Kicker
Here is a video of our Hybrid kicker. The first part show the elastic one and then you will see a 1 1/2 " bore 8 " stroke with one clippard storage tank repeatedly fire and make it over a bump 18' feet away with 30-40 psi. The system uses elastic assist tensioned up to the point that it can barely retract and lock the trigger mechanism for the next shot. With 60 psi it can shoot 25 '. It has a 9 inch leg and moves only 6". We can also fire with out air about 6-8 feet using only the elastic. During the 15 sec test at the end of the video we were able to get 4 shots off from 18 feet away the bump. All of them cleared but the last one that landed on top of the bump.
all this with only one clippard!
http://www.youtube.com/watch?v=g4-8BTtO0uE
Faridodin "Fredi" Lajvardi KD7WKD
Unread 18-01-2010, 22:34
Re: Hybrid Kicker
I've been trying to make a similar locking mechanism. Would you mind getting close up pics of that or just explaining your locking/release method?
Thanks. Looks great.
Unread 18-01-2010, 22:37
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Hybrid Kicker
It look like a normal fence latch:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
A small pneumatic cylinder should be able to release it.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 18-01-2010, 22:45
AKA: Ledge
Re: Hybrid Kicker
exactly right only Ace instead of Home depot
Unread 18-01-2010, 23:04
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Hybrid Kicker
We found that a gate latch was fine, but removing some material from the inside radius of the very tip of the release latch helped it release more smoothly.
I noticed from the video that many of the balls did not go in, either bouncing too high or not rolling up the goal ramp. I attribute much of that to the lack of carpet, but I'm wondering if you also noticed that and, if so, did anything to address it?
Thank you for posting that video, it helps us confirm that we're on the right track. Now for a decent ball control mechanism...
Unread 18-01-2010, 23:12
AKA: Ledge
Re: Hybrid Kicker
We agree carpet will deaden some of the bounce, we too removed some of the material of the gate latch. You having done all this also confirms to us that we are on the right track!
Unread 19-01-2010, 10:56
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Re: Hybrid Kicker
Nice hybrid design - I like it.
Have you given any thought as to how you will be mounting it (if you go with this design) and also allow for decent ground clearance (if you plan to go over the bump)?
Also, do you think you will need an on-board air compressor or just some pre-filled air tanks?
Unread 19-01-2010, 11:16
AKA: Ledge
Re: Hybrid Kicker
We are not going over the hump, we want the tunnel. 1 " clearance
We will have a compressor, and four clippards
We plan on having kickers on all sides of the bot full length of each side
Unread 19-01-2010, 13:46
billfunk29 billfunk29 is offline
FRC #3042 (Constant)
billfunk29 is an unknown quantity at this point
Re: Hybrid Kicker
For quick release under load I like the water ski qiuck releases. The fence latch could be modified with a ball bearing on the contact to work in similar way.
Unread 20-01-2010, 10:02
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Hybrid Kicker
We've been playing with a similar kicker but we can't seem to get our piston to fire as quickly as yours does.
If I'm understanding your mechanism correctly, the retracts the kicker to the locking mechanism and then to shoot the piston is "Fired" and then allowed to charge before the locking mechanism is released? I'm sorry if this is a dumb question but it's something we've been struggling with...
-Dustin Benedict
Unread 20-01-2010, 10:09
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Hybrid Kicker
Can you post a picture or something of a water ski quick release?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 20-01-2010, 10:55
RoboReid678's Avatar
RoboReid678 RoboReid678 is offline
FRC #2960
RoboReid678 is an unknown quantity at this point
Re: Hybrid Kicker
yes pleez do
Unread 20-01-2010, 14:09
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Hybrid Kicker
If you look at the design it's pretty clear that they are latching the kicker in a position where the cylinder is extended 3in. They charge the cylinder in this position making the energy stored in the compressed air immediately available (i.e. it doesn't need to pass through restrictive fittings etc.)
The latch is then released.
However I believe there are some very serious saftey issues coming into play here. Precharging a cylinder and using elastic bands to increase the kicker velocity puts the cylinder well outside its normal operating velocity. From other posts it appears that the cylinders will degrade and become dangers if piston is moving at speeds around 20 in/sec.
From the video I can't determine the velocity of the piston, but it appears to be moving extremely fast. Because a damaged cylinder could kill someone I highly recommend that you determine the piston velocity and if it is even 15in/sec reevaluate your kicker.
Unread 20-01-2010, 14:12
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
Re: Hybrid Kicker
The safety precautions Matt suggests are very important, not only for this type of kicker, but any kicker that has a lot of final velocity (basically any kicker than can get the ball to fly downfield).
The part that contacts the ball will be moving very fast, it needs to be very solidly attached.
Unread 20-01-2010, 14:15
Re: Hybrid Kicker
Also I believe this is the type of quick release which was discussed earlier.
http://www.defender.com/product2.jsp?path=-1|619045|619408|966099&id=195419
#1860 kicker prototype sloteera General Forum 12 04-02-2010 14:27
987 Kicker Destruction JM987 General Forum 29 23-01-2010 16:46
FRC114 Kicker Teaser James114 Robot Showcase 10 22-01-2010 16:56
kicker or linear accelerator? John G Technical Discussion 7 20-01-2010 13:48
Video of Kicker Prototypes falconmaster General Forum 52 18-01-2010 22:43
