Re: Anderson power pole connectors
As a design engineer for Anderson, I can tell you there are a couple ways to buy our connectors. The first is our online store, at http://store.andersonpower.com/. You can also find a local distributor by clicking your region on this map.
The standard FRC battery connector is what we call the "SB 50", which is our smallest multi-pole connector. Our part number 6331G2W (which says is for #10 contacts) will also accept a #12 wire. If you're looking for something smaller, the Powerpole line (which I think may be what you were asking about?) has 30 and 45 amp varieties, both of which can be ordered with a #12 contact. If you want more information, we have catalogs and datasheets available to browse. Hope this helps! |
| Anderson Powerpole Connectors | Kmo | Electrical | 4 | 14-01-2008 00:33 |
| Anderson Connectors!!!! | cdennisxlx2 | Electrical | 9 | 06-03-2006 19:20 |
| Inventor Model: Small Anderson Connectors | CraigHickman | Inventor | 0 | 31-01-2006 22:55 |
| Shipping w/ Anderson Connectors | Sscamatt | General Forum | 2 | 20-02-2005 23:59 |
| 45 or 75 amp anderson power products connectors to drill motors? | Andrew Wyatt | Motors | 2 | 20-12-2001 08:00 |
