Go to Post Neat! I like when things break, it's educational! - s_forbes [more]
Unread 19-01-2010, 10:58
dflaws dflaws is offline
FRC #2425 (Hydra)
dflaws is on a distinguished road
Viewing Program Output
How do you view text coming out of Java programs on the Classmate PC driver interface? The "System.out.println();" command doesn't show up on the "User Messages" box in the "Operation" tab. Help is appreciated!
Unread 19-01-2010, 11:24
Re: Viewing Program Output
Use the DriverStationLCD class.
Unread 19-01-2010, 11:37
James Dempsey James Dempsey is offline
Overtired Programmer
AKA: Rooster Cogburn
FRC #1559 (Devil Tech)
James Dempsey is an unknown quantity at this point
If you have a separate development computer from which you are deploying your code, the output should appear in the console. Or you could reroute your data to be displayed by sending packets to the dashboard.
James D
Unread 19-01-2010, 16:00
a kenny03 a kenny03 is offline
Robotics for life(stupid classmate)
AKA: PICKELL!!!
FRC #0219 (Team Impact)
a kenny03 is an unknown quantity at this point
Send a message via AIM to a kenny03
where and what is the DriverStationLCD class???
Unread 01-02-2010, 17:35
Web Wolf Web Wolf is offline
FRC #3012
Web Wolf is an unknown quantity at this point
I am running into a related issue. While trying to set up the camera I want it to display immages on the classmate and print out on a development laptop via serial cable, but System.out.println only sends the message to the NetBeans terminal. Is there a seprate command for sending messages via the serial port?
Unread 02-02-2010, 18:17
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
If you want to print to the serial port, you need to remove "NetConsole.out" from the ni-rt.ini file on the cRIO's FTP server. You will also need to turn the console out dip switch on. The serial console runs at 9600 baud.
Unread 02-02-2010, 20:01
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
There is a super easy way to do this, run the NetConsole program. I believe it is on the classmate. I dont have one and dont know.
The NetConsole from LabView will work just fine.
Unread 03-02-2010, 00:30
That's true...if you use the NetConsole client application, you can see the console output on both the NetBeans console and the NetConsole client.
pic: VIP Viewing Lounge Ken Platteschor Extra Discussion 16 01-05-2009 23:50
Controller Viewing help? GrammarNazi Rules/Strategy 2 13-02-2008 18:09
CMUcam Viewing neutrino15 Programming 5 16-12-2007 01:34
Viewing Angle of Camera Joe Johnson Technical Discussion 10 14-01-2005 14:11
