Go to Post I'm really impressed with how much effort we'll go to, to avoid buying a $25 servo tester. - MrForbes [more]
Unread 16-01-2010, 07:01
Think About Protecting Your Battery!
This is a good time to start thinking about the battery on robots going over the bump. Batteries have a lot of mass and are full of heavy parts like the lead plates inside each cell. Although other threads have stated that the Crio can take a lot of abuse, the battery may need some crash protection. Please check the manufacturer's specification for drop force and plan accordingly.
While you are at it, make sure that you follow the electrical rules for securing the battery in the robot. Even if you have the best robot on the field, they are not going to let you play with your battery dragging on the floor.
Unread 19-01-2010, 11:48
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Re: Think About Protecting Your Battery!
well said
Unread 19-01-2010, 13:29
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
If I had a nickel for everytime I saw a team dragging a battery in my 8 years as a mentor...
One of the most deflating experiences a team can have is to be sitting there unable to move in the elims from an un-plugged battery, so please make a simple strap to keep it in place as a bare minimum. All you need to do is take some velcro and rivet it to your frame sandwitched between a couple thin sheets of Al. And for those of you that want a Martha Stewart tip for dressing it up, take the scraps of fabric from making your bumpers and put them on the adhesive section on the velcro.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 19-01-2010, 13:35
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Just a suggestion http://andymark.biz/am-0477.html The simplest things can change the whole game
Unread 19-01-2010, 16:31
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Another concept you can do to hold it in place (we did it last year and it worked perfectly) - build a little "seat belt" for it. Simply buy a buckle like this:
, work in two short nylon straps, and you're set! We found that a simple pop-rivet was plenty to hold the ends of the belt in place, and with the buckle right on top of the battery it was extremely easy to undo when a battery needed to be replaced.
Unread 19-01-2010, 16:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We've used the plastic buckle for the past 3 seasons, it works great. Velcro is also a great idea. And the strap and block kit that AndyMark sells also looks very good.
I wonder about the shock loading thing....has anyone experimented with foam or other resilient materials? I wonder if the foam used in pool noodles would be good for this? It seems to be similar to one type of race car roll bar padding.
Unread 19-01-2010, 16:49
O-H
FRC #0048 (Delphi E.L.I.T.E.)
That sounds rather painful for Al.
Add another vote for the quick release plastic buckle. Search "48 Flips" on Youtube - yeah....we were using one of those buckle straps during that. No issues or damage at all.
Finally - please don't ever use your battery as the counterbalance of your arm. Yes, I've seen this on a FIRST robot. Yes, it was deemed legal. Why? I have no clue!
Unread 19-01-2010, 20:38
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
http://www.youtube.com/watch?v=CjHMb55EXmY
I don't know if that is considered EPIC WIN or FAIL
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 19-01-2010, 21:15
Best Available Data
FRC #1778 (Chill Out!)
If memory serves, one year 116 asked if they could use additional batteries as counterweight. Although, knowing those jokesters, it might well have been in jest.
On topic, we used a zip tie. Every match we'd ziptie the connectors together and cut it loose at the end of the match. We tried a velcro strap, but it was always getting in the way, so we found zipties to be a less obnoxious solution.
Unread 19-01-2010, 21:27
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
Thanks for the advice. We usually make a little cradle for our battery out of aluminum L brackets. The cradle is riveted together and then bolted to the frame. On the shafts of the four bolts we put rubbers spacers to help absorb the shock. Then we fasten the battery in with velcro. It works great, and we've never had any problems with it.
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 19-01-2010, 21:38
Guys,
I think you were missing the point. I am suspecting that robots coming off the bump this year will produce some serious g forces on the battery. In addition to the secure attachment, we may also need to consider some shock protection for the battery.
Unread 19-01-2010, 21:41
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Haven't people heard of a big old hunk of iron?
I remember in 2003 when a team at GSR was backing up and knocking over bins at the top of the ramp in autonomous at a very high rate of speed, their battery went FLYING out of the robot several times and landed by the driver station. Funny as a spectator, bad for the team!
Thanks Al! It's only helping yourself and your team if you ensure that your battery is attached safely. It's not cool to have a lose battery in FIRST.
1058 PVC Pirates 2016 - xxxx
Unread 19-01-2010, 21:47
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
I think we will be putting the battery in the middle of the robot rather than in the back as it usually has been. Should cut down on the bangs and bumps.
2016 Central Illinois Winner. Curie Division finalist
Unread 19-01-2010, 21:55
MrForbes's Avatar
AKA: Jim
Guys,
I got it, I don't know if anyone else did....but thanks for the reminder again.
Unread 19-01-2010, 22:08
AKA: Brendan Browne
If teams have any of the memory foam left over from the goals, that might be a wise material to help cushion the battery from g forces.
Al, I had an impression of both g force protection and securing the battery from your post. I have seen too many robots which are not secured down, and I am sure that you have more of the same in your years as an inspector.
Thanks for the insight Al!
Question about battery placement itsme Electrical 7 11-02-2008 16:18
pic: Something to think about... CD47-Bot Extra Discussion 27 11-07-2004 02:27
Think about it Raul General Forum 8 07-04-2003 15:00
think about it E. The Kidd CD Forum Support 2 01-12-2001 22:16
One way to think about it. Joe Johnson General Forum 16 07-10-2001 21:21
