Go to Post They could release an update saying they were going to give every team free puppies and kittens, and many teams would vehemently complain this change was too late to budget dry kibbles into their budget. - artdutra04 [more]
Unread 19-01-2010, 12:34
MechJim's Avatar
MechJim MechJim is offline
AKA: Jim Morris
FRC #3284 (Laser)
MechJim is an unknown quantity at this point
Torsion Springs
Does anyone know a reason/rule that would prevents us from using torsion springs to provide the motive force on a kicker mechanism?
Most rotation kicker type mechanisms that I have seen here are using the surgical tubing which take up a lot of space. Our thought is properly sized torsion springs at each end of the kicker axle could do the same job and not require the robot space that an extension type spring would require.
Thanks
MechJim
Unread 19-01-2010, 12:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Torsion Springs
From my reading of the rules, the only things that would prevent it are if it's unsafe, or if you use illegal materials (ie. make sure you use springs that any team can buy).
Neat idea! and there are a lot of them available from places like McMaster Carr
Unread 25-01-2010, 12:58
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Torsion Springs
they also work well in the drivetrain
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 25-01-2010, 12:59
carbuff2228's Avatar
carbuff2228 carbuff2228 is offline
Scouting Mentor -College student
FRC #2228 (Cougartech)
Team Role: Scout
carbuff2228 is on a distinguished road
Re: Torsion Springs
no it states in the rules that you can use them as long as they are safe.
Unread 25-01-2010, 14:58
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: Torsion Springs
Do Home Depot, Lowes, or any other local vendors carry a good selection of torsion springs or springs in general?
Unread 25-01-2010, 15:01
MrForbes's Avatar
AKA: Jim
Re: Torsion Springs
Our local Ace Hardware store has some, but not nearly the selection you probably need to do it right.
Unread 25-01-2010, 15:04
Re: Torsion Springs
Jim,
Under <R01>
Teams must be very careful when incorporating springs or other items to store energy on their ROBOT by means of part or material deformation. A ROBOT may be rejected at inspection if, in the judgment of the inspector, such items are unsafe
I would suggest that you bring along the specification sheet for the spring you intend to use and have it available during inspection. The inspector will need to compare your use with the sheet. We are just as concerned with overstressing the spring during charge as we are as to what happens in a dry fire. Springs do have a tendency to shatter under conditions beyond what their design intends. Inspectors tend to err on the side of safety in these issues and may involve the UL Safety Advisors much as we did with propellers last year.
Unread 25-01-2010, 15:07
MrForbes's Avatar
AKA: Jim
Re: Torsion Springs
Al, that's another good reason to order the springs from a supplier like McMaster-Carr....they have the specifications on their online catalog.
segway project: where to get torsion springs (around 20-40ft/lbs) dfukuba Technical Discussion 8 31-07-2008 07:33
Springs? Robo_Coyote Kit & Additional Hardware 3 13-01-2007 15:51
looking for a torsion spring tml240 Technical Discussion 1 03-02-2004 12:51
Torsion Spring Specs ateene Technical Discussion 0 22-01-2003 15:42
springs CharlieWilken Technical Discussion 3 30-01-2002 19:39
