Go to Post ...when you see someone post about something they don’t like, please don’t post another “I’m sick of all this whining” type of post. If you disagree with them, try to offer an intelligent argument back. - Phil 33 [more]
Unread 19-01-2010, 03:44
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Mecanum Specifics- Layout, Ratios, etc
As a second year team, we're getting prepared to start experimenting with our first Mecanum drivetrain. We have a set of the 6" wheels from AM en route, and while we wait we were doing some digital design. I have a few questions that I was unable to answer from previous threads:
1. Does the layout of the wheels have a big impact on the overall performance of the bot? We could either lay them out in a square or rectangle - does it make a big difference (especially from a programming standpoint)?
2. Is maximizing the footprint a big deal? Put another way, should the wheels be pushed as far toward the corners as possible?
3. What have you used as a successful final gear ratio, and what type of gearbox did you implement. A few earlier posts suggested direct drive off a Banebots transmission, either 12:1 or 9:1. We don't have any of those, and rather than dropping $400 on some trannies we'll probably try to adapt the Toughboxes we've got. There are some good ideas floating around, just wanted to get a feel for what others have tried.
Thanks for the support.
Unread 19-01-2010, 04:03
Re: Mecanum Specifics- Layout, Ratios, etc
1. Layout doesn't seem to have a big impact. Main place might be in turning.
3. The team I worked with that used them in 2008 used something close to a 1:1 off of a Toughbox. I'm still not sure that was fast enough. I'm not sure what the ratio was off a 2005 KOP tranny (effectively a Toughbox, IIRC) when my team tried it in that year.
If you use a toughbox, I think there's a speed mod you can do pretty easily--you may want to do that.
Unread 19-01-2010, 04:19
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
We did this in 2008 (taking out a stage of reduction, though andymark sells gears for different reductions), and it reduces the gearing of the toughbox from 12.75:1 to 3.57. If you want help doing this let me know.
Unread 19-01-2010, 08:34
pfreivald's Avatar
AKA: Patrick Freivald
One might want to check if 3.57:1 is enough for a mechanum drive to get over the ramps. I know 12:1 works, but I'm not sure about 3.57:1.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 19-01-2010, 09:15
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
Have you traversed the ramp with 12:1?
Unread 19-01-2010, 12:37
dtengineering's Avatar
AKA: Jason Brett
We used 12:1 banebots transmissions directly driving 8" AM mecanums in our Rack'n'Roll robot. It worked pretty well http://www.youtube.com/dtengineering#p/u/12/gyn9e0cT3-A and we were able to make it up a 30 degree incline.
The banebots trannies needed the long output shaft that is currently backordered, as are the BB P80 transmissions.
An AM toughbox with the long output shaft for each wheel should work well, too... although I'd highly recommend getting the aluminum gears to lighten it up, and maybe even speedholing them a bit. Four transmissions and ten pounds of wheels can start to add up quickly.
Jason
Unread 19-01-2010, 12:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It might have affect how tippable your robot is. See if you can understand why by reading this old white paper.
http://www.chiefdelphi.com/media/papers/1974
As for programming, I think it does not make much difference, although the "spinning" thing probably works best with the wheel/floor contact points in a square configuration.
2009 Human Player Specifics Chris_Elston Rules/Strategy 16 22-03-2009 19:07
Website Award - Specifics? Tanner Awards 2 19-08-2007 17:37
Big CIM Motor Specifics jakey Motors 1 13-01-2006 01:00
Problems Getting Started etc. etc. Descartes FIRST Lego League 5 09-11-2004 07:32
Microsoft specifics P.J. Baker General Forum 5 21-12-2001 03:15
