Go to Post How many FIRSTers would quit if they found it was bad for them? I think most FIRSTaholics are thirteen steppers ;) - phrontist [more]
Unread 17-01-2009, 15:51
jack.j.191 jack.j.191 is offline
FRC #0191 (X-Cats)
jack.j.191 is just really nicejack.j.191 is just really nicejack.j.191 is just really nicejack.j.191 is just really nicejack.j.191 is just really nice
Possible Penalties
What are all of the possible penalties?
We're trying grade our drivers test and having a full list would make the process a lot faster.
Unread 17-01-2009, 16:03
Re: Possible Penalties
Here are the rules that will give you a penalty/card for violation:
<S01>, penalty/disable
<S02>, red card
<S04>, penalty/yellow
<G16>, <S04> invoked
<G20-B>, penalty
<G20-C>, penalty
<G21>, penalty
<G22>, penalty
<G23>, double penalty
<G24-A>, penalty
<G24-C>, penalty
<G25.1>, penalty and no effect (descoring rule)
<G26>, disable
<G27>, disable after a time
<G28>, penalty
<G29>, disable
<G30>, disable
<G32-E>, penalty
<G32-F>, penalty
<G32-G>, penalty
(note--<G32> is the contact rule, which says that any contact may be penalized or red-carded
<G33>, disable/red card
<G34>, penalty
<G35>, red card
<G37>, penalty
<G38>, penalty
<G39>, penalty
<G40>, <G40-A>, penalties
<G40-C>, <S02> invoked
<G41>, disable and red card
I leave you to read the listed rules to find out just what the actions are that will trigger a penalty.
Unread 17-01-2009, 16:15
FRC #0191 (X-Cats)
Thanks, this will make things much easier .
Unread 17-01-2009, 18:03
GaryVoshol's Avatar
Cogito ergo arbitro
I'm sure the way Eric found these was to search the manual pdf's for the partial word "penalt" (that way, you get both singular and plural). Don't forget to use the latest versions of the files, because there have been 2 or 3 added since kickoff.
(since 2004)
Unread 17-01-2009, 19:13
Actually, I didn't. I scanned through, looking for PENALTY and any hints of "disable" and "disqualified". In retrospect, I should have used the search, but didn't.
Unread 17-01-2010, 14:06
moonwatcher211's Avatar
moonwatcher211 moonwatcher211 is offline
FRC #2349
moonwatcher211 is an unknown quantity at this point
ok... so what degree of contact is considered illegal?
Obviously, robots bump into robots. You cant help that. But can a robot initiate contact with another robot, even if minor?
Unread 17-01-2010, 14:10
GaryVoshol's Avatar
Cogito ergo arbitro
Of course a robot can initiate contact with an opponent. You are allowed to pin for up to 5 seconds (<G39>); how would you do that without contact?
Look at <G36>, <G37> and <G38> regarding allowable and disallowed robot contact.
(since 2004)
Unread 19-01-2010, 13:55
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
When considering penalties, we feel it is important to consider the red and yellow flag situations that arise AND the carry-forward status that results. Namely, if you are flagged in Q-1 (red or yellow) then you'll start out yellow flagged in Q-2. (general case: flag in Q-n means yellow flag in Q-n+1 where n<6) Unlike yellow cards in soccer play, once carded at FRC tournament your team remains under scrutiny for the rest of the qualification round.
Echoing a famous "cop" show line: Be careful out there!
Unread 19-01-2010, 14:32
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
That is why I believe in the 1st few weeks, we will see a lot of 0-0 matches. Penalties will play a hugh roll this year, even more so than 2008.
Unread 19-01-2010, 15:33
Figure I may as well compile a list for this year...
Just remember, I will only give the rule number and what the penalty is. You get to read the rule to find out what the penalty is for.
Section 9:
<T14>, Yellow Card
<T15>, Yellow Card
Section 7:
<S01>, Penalty, disablement
<S02-A>, Penalty, disablement
<S02-B>, Penalty
<S04>, Penalty, potential Yellow Card (Note: this penalty may also include a trip to the inspection station to deal with any Section 8 issues.)
<G10>, no robot participation in the match for the offender
<G11>, arbitrary repositioning by the Head Referee
<G12>, Penalty, Yellow Card
<G15>, Penalty
<G16>, Penalty, Yellow Card
<G17>, Penalty, plus 1 Penalty per 2 additional seconds that a ball isn't returned
<G19>, Penalty, Yellow Card
<G20>, disablement
<G22>, Penalty, disablement
<G23>, Penalty, disablement
<G24>, warning, disablement if disregarded
<G26>, potential disablement and/or potential trip back to inspection
<G28>, 2 Penalties, plus 2 penalties and a Yellow Card for first contact, plus 2 penalties per contact after initial contact
<G29>, Penalty, plus Red Card if remedy not immediately attempted
<G30>, Penalty, Yellow Card
<G31>, Penalty, Red Card if intentional or damaging
<G32>, Penalty, Red Card if intentional
<G33>, Penalty
<G34>, Penalty, Red Card if intentional
<G35>, Penalty, Red Card if intentional
<G36>, Yellow Card
<G38-A>, Penalty, Red Card if egregious or damaging
<G38-B>, Penalty, Red Card
<G39>, Penalty per violation
<G40>, disablement if damaging, dangerous, or repeated, Red Card if intentional
<G41>, Penalty, Red Card if play impeded
<G41-A>, Penalty
<G42>, Yellow Card
<G43>, Penalty
<G44>, 2 Penalties per ball
<G45>, Penalty
<G46>, Penalty, Yellow Card if no attempt to remedy
<G47>, 2 Penalties per ball
<G49>, Penalty (unless operator or console safety is an issue)
<G50>, Penalty
<G51>, disablement, Red Card
<G52>, potential Red Card
28 separate Penalties possible (3 double penalties contingent on number of items affected)
11 separate Yellow Cards possible
11 separate Red Cards possible
9 separate disablements possible
2-3 other minor penalties possible
Multiple combination penalties
Compared to last year's:
21 Penalties (1 double penalty)
2 Yellow Card
4 Red Cards
7 disablements
Few combination penalties.
penalties values??? colin340 Rules/Strategy 4 08-03-2008 21:37
POLL - Penalties Steve W General Forum 30 18-03-2005 14:03
Penalties raphael General Forum 7 08-03-2005 14:50
Penalties JVN General Forum 15 27-10-2003 17:21
