Go to Post If regolith ever makes a return, I will jump out of a window. - Oblarg [more]
Unread 19-01-2010, 12:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How do those winch-loaded shooters work?
Originally Posted by aldaeron View Post
I don't see what a CIM motor can't be engaged and the motor controller switched to Coast while shooting. You would be rotating through a angle of less than (180 degrees * Gear Ratio). The motor will not spin faster than the ~5500 rpm it is rated for and the power generated seems negligible. What else makes these motor attached designs less successful?
I suggest you give it a try, before you incorporate the idea into your final robot design. Shouldn't be too hard to make a prototype?
Unread 19-01-2010, 12:54
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Parts on order to test this weekend!
It just seems like a lot of weight to add to use an AndyMark shifter mechanism. If it is just some amount of drag, we can get a bigger torsion spring.
Unread 19-01-2010, 13:56
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
I should have mentioned earlier that our dog gear release was only based on the supershifters. For the dogs we used lovejoy connectors found in the kit a few years back. The rest was improvised from what we had around. It was messy though, and I think a pneumatically actuated rachet might be a better way to go.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 19-01-2010, 14:02
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Page 1440 on McMaster may be of interest to you.
AKA: -matto-
FRC #1410 (Kraken)
We are trying using the ratchet from a ratchet strap and half the handle. Has a nice linear slide to disengage and can hold ~1000 lbs according to the box rating.
Unread 20-01-2010, 00:45
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Team 3135, Robotic Colonels, F.W.Parker - Chicago IL
We are looking for cheaper ways to have a programmed windup with instant release of tension at any point in the wind up cycle (no gate latches, thank you). This way we can control the strength of shots in programming
We also want the winder scheme to quickly transition from release to starting next pull cycle without wasting time going through 180 degrees of rotation at a slow RPM.
Finally, we want ALL the energy stored sent to the kicker, not wasted on spinning up some freewheeling masses or linkages that remain attached to the tensioning cable after release. It should be like with a crossbow, where only the string's mass is added on to the mass of the arrow being accelerated.
We are prototyping such a scheme now & should be firing kicks off by Friday.
-RRLedford
Ultrasonics: Will it work and how to make it work DavidB Electrical 2 17-01-2009 16:27
How do the Shooters work? Akash Rastogi Technical Discussion 31 06-04-2008 03:10
Linear Shooters - How did you do it? Leav Technical Discussion 19 10-03-2008 17:20
How many shooters do we have??? Kevin_547 Scouting 18 20-02-2006 11:05
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
