Go to Post Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. - RoboChair [more]
Unread 19-01-2010, 08:19
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Anderson power pole connectors
Any suggestions on the best place to buy Anderson PowerPole connectors? i need them in 12awg wire size.
Thanks
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 19-01-2010, 08:23
Re: Anderson power pole connectors
The Anderson Power Products come in smaller sizes and we have used the 35 and 45 amp connectors for many years. You can find them at Terminal Supply or West Mountain Radio. West Mountain also sells a great ratcheting crimper.
Unread 19-01-2010, 09:02
Ralph Lambert Ralph Lambert is offline
Mentor - Team 1094
None #1094 (Channel Cats)
Ralph Lambert will become famous soon enoughRalph Lambert will become famous soon enough
We got our last batch from Powerwerx.com. They also carry the 15 amp connectors. I also recommend the West Mountain crimper.
Unread 19-01-2010, 11:26
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
As a design engineer for Anderson, I can tell you there are a couple ways to buy our connectors. The first is our online store, at http://store.andersonpower.com/. You can also find a local distributor by clicking your region on this map.
The standard FRC battery connector is what we call the "SB 50", which is our smallest multi-pole connector. Our part number 6331G2W (which says is for #10 contacts) will also accept a #12 wire.
If you're looking for something smaller, the Powerpole line (which I think may be what you were asking about?) has 30 and 45 amp varieties, both of which can be ordered with a #12 contact.
If you want more information, we have catalogs and datasheets available to browse. Hope this helps!
Jeff Waegelin
Unread 19-01-2010, 11:32
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
I've had great success buying them from Powerwerx. They have a lot of colors.
Unread 19-01-2010, 12:49
Bob Steele's Avatar
AKA: Bob Steele
We have purchased these connectors from Helmar for the last two years and are very happy with the price and with the service. (these are the battery connectors.... but they have others also.)
https://www.helmarparts.com/ProductD...uctCode=6331G1
Do you guys use this crimper
http://www.westmountainradio.com/PWRcrimp.htm
to do your crimping on the battery terminals? Do you have to use one of the accessory dies or do you use the 45 pound setting?
thanks
R
Unread 19-01-2010, 13:52
Bob,
The 50 amp pins use a different crimper. However the battery plugs we get appear to be done on a machine. The contacts come on a reel.
Unread 19-01-2010, 14:06
El Jefe de 148
Bob,
Al,
You're right - the KOP battery plug contacts are all machine crimped. There is a hand tool we sell designed specifically for those contacts, but it's pretty pricey ($200+). Don't know if there are any cheaper alternatives out there.
Jeff Waegelin
Unread 20-01-2010, 16:42
Mike9966's Avatar
Mike9966 Mike9966 is offline
Mentor Mike
FRC #2846 (Fire Bears)
Mike9966 is an unknown quantity at this point
Say Jeff,
I'm wondering about something. I've heard that there are 2 different grades of housing for the powerpole line using the 15,30, and 45 amp terminals. One is supposed to have a tougher plastic housing supposedly.
Can you comment on that?
Thanks
Mike
Do the best you can! Always
Go FireBears
2009 10000 Lakes Finalists, thanks 2825 & 2177
2010 10000 Lakes quarter finalists
2011 Duluth and 10000 Lakes
2012 Superior, and 10K Lakes, Qt finals, MRI
2013 Northern lights, 10K Lakes-Semi finalists, MRI, River Rendezvous, Minne Mini
2014 Northern Lights, 10K Lakes
Unread 20-01-2010, 17:05
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I know I purchased them from McMaster (or a knock off of them) but I couldn't find the part number when I went to their website.
Anybody else know if they still carry them?
Joe J.
Team #88, TJ2
Unread 20-01-2010, 17:25
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
McMaster still carries them.
http://www.mcmaster.com/#power-connectors/=5gmmw8
They are on page 766.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 20-01-2010, 21:01
Mike,
You may be thinking of the connector type. There are HD terminals that make a locking condition when mated rather than the simple wiping of the standard contacts. There is no difference in current handling just a much more robust connection. We have used the McMaster contacts in the past but are much happier with the Power Pole.
Unread 20-01-2010, 22:55
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Fellow Canadians:
http://rosspar.com/
Please mention to them that you are using them on a FIRST robot!
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 22-01-2010, 16:02
Mike9966's Avatar
Mentor Mike
Hi Al,
Well, no, I had heard from a fellow ham that there were different plastics, or perhaps a heavier wall in some of the housing that hold the 15-45 amp units. I was hoping since Jeff worked there he would know.
I've always been very happy with them since I started using the proper crimper. They are on every thing 12volt I own practically. Very handy.
73
Mike
KB0ozn
Mike,
Go FireBears
Unread 22-01-2010, 16:16
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Since it sounds like several people here have experience with them... how do you secure them to your board/robot? We have several hooked together, and it seems like the mounting holes that are formed between two of them are sized for a size 2 screw, which isn't in our normal stock. In fact, the smallest diameter we have easily available is a 4-40. I'm hesitant to use that, in case it breaches the housing wall and causes a short.
The other option we're considering is a simple bracket to hold the connectors down. While it would be easy to make and work without a problem... it wouldn't look as nice as using screws in the provided holes - and we're working this year to have the cleanest, coolest, best looking electrical system yet. That reminds me... i need to take some teaser pictures tomorrow...
Anderson Powerpole Connectors Kmo Electrical 4 14-01-2008 00:33
Anderson Connectors!!!! cdennisxlx2 Electrical 9 06-03-2006 19:20
Inventor Model: Small Anderson Connectors CraigHickman Inventor 0 31-01-2006 22:55
Shipping w/ Anderson Connectors Sscamatt General Forum 2 20-02-2005 23:59
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
