Go to Post ...and part of being Graciously Professional is knowing what your job is and how to perform the duties of it accurately. - jamie_1930 [more]
Unread 18-01-2010, 15:57
ophir ophir is offline
FRC #2230
ophir is an unknown quantity at this point
Bevel Gears...
Hello all,
I have some problems using the design accelerator...
I want to create a bevel gear with 16 teeth to 16 teeth, module 1.5 and face width of 5.5 mm (about 0.22 in)... The program "claims" that the calculation indicates about a design failure... And it's not true - i have this gear in my hand... What should I do??
Unread 18-01-2010, 16:09
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Re: Bevel Gears...
I don't know the real way to get around it but after some experimentation with the design accelerator i found that if you mess with the input values enough in the calculations section it will eventually accept the design. Or i you don't have the time just say ok to the warning and it will create the bevel gears anyways.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 19-01-2010, 15:01
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Bevel Gears...
The previous suggestion is close to the mark. Generally the values for inputs such as Horse Power are too high for the smaller gears you use. Reduce this value based on the HP of the motor driving the gear and then recalculate. I also try making the input a very small number such as 0.001 HP just to check if that is the problem.
Phil
phil.dollan@autodesk.com
Help: Bevel Gear Mounted On CIM Shaft? 854 bears Motors 16 24-07-2009 13:50
Replacement for Bevel Gears? Greg Technical Discussion 3 30-03-2003 19:56
Bevel Gears on Drivetrain archiver 2001 7 23-06-2002 22:57
45 Bevel Gears Ryan Curry Technical Discussion 1 03-04-2002 09:36
