Go to Post I will be happy if these die a quick and silent death. - Cory [more]
Unread 19-01-2010, 15:23
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Rookie Team 3357 The COMETS Kicker Prototype
very nice kicker with good loft.
Originally Posted by BrianT103 View Post
Does the flapper stay within the 2 inches/2 second rule
There is no 2" rule. You are allowed to extend any kicker or ball interaction device up to your bumper parimiter. A pool noodle 2.5" mounted on 3/4" plywood gives you a ~3.25" bumper parimiter past your frame parimiter. Let's not confuse teams with inacurate rules.
Unread 19-01-2010, 15:31
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by GGCO View Post
Here's the latest video guys!
youtube.com/user/cometsrobotics
Where are your safety glasses?
You are going to remove those outlier parts of the frame, right?
(since 2004)
Unread 19-01-2010, 18:28
aclapper21 aclapper21 is offline
FRC #3015
aclapper21 is an unknown quantity at this point
We have been working with the pneumatic system but for some reason we can't see to get enough power/pressure from the pneumatics system. We are using the max of 60 psi. Is there any advice on how to improve the pneumatics.
Unread 19-01-2010, 19:28
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I am very novice with pneumatics but I have read alot because I wanted to use them this year.
Try-
1. using some surgical tubing as a spring
2. moving the pivot points of the cylinder
3. this is a little complex, but some teams have a restraining pin. They fire there pneumatics, but they can't move anywhere until the pin is pulled. Pull the pin and it goes. This helps because the 1/8" tubing can be very restrictive to air flow.
Unread 19-01-2010, 20:56
Homsar66 Homsar66 is offline
AKA: Ryan
FRC #0122 (NASA Knights)
Team Role: Human Player
Homsar66 will become famous soon enough
Yeah, there's no real way to increase the flow legally. The best way is to preload the cylinder so it doesn't have to vent 60 psi from the other side. Although I've been trying to find a piston with two ports for each stroke, so you could use two solenoids and double the flow.
PS- Your team has my favorite number of all time, I'm into vintage paintball markers and that number just so happens to be the name of the only true paintball revolver ever to make it into production.
Unread 19-01-2010, 23:01
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
Hey a team in our own backyard, Forest Hills right? Looks like you guys are doing great, One thing i would suggest, that being a rookie team is getting that kitbot up and running, if that is going to be your drive platform, so that way the programing team and Drive team can get a crack at it and work out the bugs.
If you guys ever need anything Team Enigma 2075 is always ready to help a neighbor, good luck and see you at one of the competitions, i hope.
Unread 19-01-2010, 23:06
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Just a note: You are saying that your ball gets over the bump, but in fact, the only foolproof way to test if it can is to place the robot 15.5 feet away, and then fire your device. It is successful if you can do it from the furthest possible point!
Anyways, it looks like a great device!
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
Team 1930 Comets (Video) Alex Cormier Robot Showcase 3 22-02-2008 08:47
pic: Team 1930 Comets Alex Cormier Robot Showcase 6 20-02-2008 22:54
pic: Team 1501's shooter...errr kicker Wayne Doenges Robot Showcase 9 14-02-2006 14:44
Rookie Team 1746 creates it's first prototype robot Snappel328 Robot Showcase 23 08-01-2006 22:24
