Go to Post Maybe FRC WILL casue world peace, who knows, eh ? - Tottanka [more]
Unread 18-01-2010, 13:51
team1631's Avatar
team1631 team1631 is offline
FRC #1631 (Rockin Robots)
team1631 is an unknown quantity at this point
Cool Frame design question
We are having a debate about our frame design. Could someone give us some input. We are wanting to create a 3 inch lip on the front of the frame and then attache the bumper giving a total of six inches. The lip would not constrain the balls movement. I am saying the frame has to be flat on all sides but others say the design is ok because it does not constrain the balls movement and is inside the frame perimeter. Thanks for any insight.
Unread 18-01-2010, 13:55
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Frame design question
Can you support this with a rule?
If the bumpers will be attached to the lip of the frame and the lipped part still fits within the 28x38 footprint I see no rules that would restrict such a configuration.
Unread 18-01-2010, 13:56
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
I would suggest that you continue the lower part of the frame all the way to the front of the robot and have an opening in the front to allow for balls to come in. That way balls won't slip out underneath the sides of your robot/bumper perimeter like you do now.
Good luck!
1058 PVC Pirates 2016 - xxxx
Unread 18-01-2010, 13:58
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Why wouldn't you want it to help hold the ball?
And to lend you insight, read rule <R19> and the associated diagram. assuming your "lip" does not allow the ball more than 3" under the FRAME PERIMETER, I see no issues.
Be sure to understand the difference between FRAME PERIMETER and BUMPER PERIMETER.
Also, look at <G30> part A in regard to the "ball hitting device" mechanism.
Unread 18-01-2010, 14:19
team1631's Avatar
We were interpreting the rules as no corralling or holding the ball. Maybe we are reading to much into the possession rule. It would be better if we could put sides on the frame to keep the ball from sliding out.
POSSESSION: Controlling the position and movement of a BALL. A BALL shall be considered in POSSESSION if, as the ROBOT moves or changes orientation (e.g. backs up or spins in place), the BALL remains in approximately the same position relative to the ROBOT.
Unread 18-01-2010, 14:41
Matt C's Avatar
FRC #1468 (J-Birds)
POSSESSION is legal. (albeit one ball at a time)
CARRYING is not.
CARRYING is POSSESSION not in contact with the field.
So as long as your are not lifting up the ball...
Refer to rules <G43> and <G44>
Unread 18-01-2010, 14:46
team1631's Avatar
cool thanks.
Team,
If your design is a way to massage the 3" intrusion rule consider that the attachment for the bumpers is the edge of the 3" rule. You can make the shape of the robot under the bumpers whatever way you want, but you will be called if in the opinion of the refs, a ball enters more than 3" beyond the frame perimeter. The drawings in the manual R19 are very specific.
Unread 19-01-2010, 17:05
Zanfardino2892's Avatar
Zanfardino2892 Zanfardino2892 is offline
AKA: Mark Zanfardino
FRC #2892 (Hottie Botties)
Zanfardino2892 is an unknown quantity at this point
So is having multiple free spinning balls in front of your robot with general control of position illegal or would it be considered possession of multiple balls? Or are you not even allowed to intentionally go after multiple balls?
Unread 19-01-2010, 17:11
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
If the balls are free spinning and not controlled by any mechanism on your robot they will not stay in the same position relative to the robot if you back up or turn your robot. When backing up the balls will stay in their same absolute position as your robot moves away, and when turning they will at there will be a relative movement across your robot sideways.
Based on this it would be legal to have multiple balls being pushed by your robot.
Unread 19-01-2010, 17:14
what if the balls are3 only controlled or held by a light suction by either rollers or fans? then they'd still have a tendency to move with the robot but not truly held
Unread 19-01-2010, 17:18
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The definition of POSSESSION is spelled out pretty clearly in the rule you quoted. A ball is either possessed or not, it can't be lightly possessed or sort of possessed.
If you back up and/or turn with a roller or suction the ball will probably stay in the same position relative to the robot (otherwise what is the point of using the device?) so it would be considered POSSESSED. You could only possess one ball at a time in this manner without receiving a penalty.
Unread 19-01-2010, 17:21
ok. so controlling the tendency of a ball to roll toward a robot without grabbing onto the ball is that considered possession?
Matt C's Avatar
FRC #1468 (J-Birds)
You can only control one ball:
If you have a ball magnet/suction/roller/dark matter/whatever device that "held" or "controlled" balls and more than one ball enters it or touches it, I can almost guarantee you'll get a penalty.
Unread 19-01-2010, 17:27
Ok. That's what I thought, thank you. You wouldn't happen to be a member of the Robovikes would you?
Robot Design: Frame Perimeter? IamMisplaced Technical Discussion 7 17-01-2010 15:03
pic: Frame Design Shira Extra Discussion 10 01-02-2009 14:06
robot design question Otaku Rules/Strategy 29 05-01-2009 19:21
pic: 1305 Frame design with trannies CD47-Bot Robot Showcase 19 25-09-2004 01:13
a web design trivia question robot180 Website Design/Showcase 5 17-10-2003 19:46
