Go to Post Instead of lowering a team's expectations, let's raise the amount of competitive resources available to them. ;) - artdutra04 [more]
Unread 19-01-2010, 17:52
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Gyro Smoking
We opened up the Basic Main code and ran it on the cRIO and less than 30 seconds later, the gyro burst into smoke.
It is extremely hot to the touch and the chip fell off of the circuit board. Our electrical guys have no idea why this happened and we can't give them a logical answer besides it was plugged in wrong which they say it wasn't. Any ideas?
We have used this same gyro in past years and it has worked without problem
Unread 19-01-2010, 18:10
Re: Gyro Smoking
Could you take a photo of it so we can see the wiring?
Also, I like software that can set the world afire...
Unread 19-01-2010, 18:24
Re: Gyro Smoking
here you go.
Sorry about the bad quality, the only member with a camera is currently getting food so we had to use a phone camera.
Unread 19-01-2010, 19:01
Re: Gyro Smoking
Well that's not what it is supposed to do!
I haven't heard of any of the other 2009 Gyro's having thermal events, so I'd love to hear more details. Perhaps you some how got the power reversed?
Fortunately, you should have another one in the 2010 KoP.
Unread 19-01-2010, 19:07
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Gyro Smoking
Originally Posted by Sauce View Post
here you go.
The other end of that wire is just as important as the end pictured for determining if it was wired correctly
Unread 19-01-2010, 19:10
Re: Gyro Smoking
that's what the electronics guys gave me. We took it off the bot and I think we threw it away. The 2010 gyro seems to be working, but we always have hands on the E-Stop button just in case.
EDIT: Check that, we still have the gyro, I'll see if I can't get a picture for you
Unread 20-01-2010, 07:41
Re: Gyro Smoking
Just a thought...The mounting holes for the board are part of the ground plane so if you have an electrical problem on the frame, you may have run a lot of current through the board. Double check your other robot wiring before you hook up the second device. The Crio chassis is also tied to the negative terminal of the battery and needs to be isolated from the frame.
Unread 20-01-2010, 08:49
Re: Gyro Smoking
Good call, Al. Shorting the Gyro's ground to the frame could easily create this problem.
There is a small gap between the mounting holes and the ground plane, but it could easily be bridged by e.g. using a metal standoff/nut that is too big or too tight. Or, it could be bridged by mounting it too close to the frame, and having one of the soldered leads hitting the frame.
Unread 08-02-2010, 13:01
stevethetinker stevethetinker is offline
FRC #1288 (RAVEN)
stevethetinker is an unknown quantity at this point
Re: Gyro Smoking
The book says to mount it with plastic hardware. The short could certainly do it. I saw one post where they had hooked their gyro to a PWM output. That could do it too.
Unread 09-02-2010, 00:26
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Gyro Smoking
I just tried our KOP Gyro (fresh out of the bag).
Ours also got hot as soon as I plugged it in.
As an experienced electronics guy, my nose is sensitive to "hot" smells, so I caught it pretty soon.
I checked the wiring at both ends, and went back to the online docs.
No clear reason for the heat. (Wiring looks clean & polarity was correct.)
I tried it again (double verifying plug polarity) and it still gets hot (almost too hot to touch)
Doesn't seem right. So I went looking, and found this thread.
Ours wasn't mounted at first, so it's not a chassis short.
Anyone else have ideas?
Phil Malone
http://www.GEARSinc.org
Unread 09-02-2010, 03:53
dragon72950 dragon72950 is offline
FRC #0675
dragon72950 will become famous soon enough
Re: Gyro Smoking
i would check to see if there are any vents on it that are blocked and if there aren't any vents i would take off the casing(if possible) and cut a couple of slts for vents(if possible if not a cooling fan could do also)
DO A BARREL ROLL
Unread 09-02-2010, 03:55
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Gyro Smoking
I don't mean to be rude but this makes absolutely no sense.
Check out the picture earlier in this thread to see what component is being discussed.
Unread 09-02-2010, 07:41
Re: Gyro Smoking
Phil,
The only thing to check for is imperfectly etched boards. There may be a few traces that are close together that didn't get fully etched. Also possible that you have a solder bridge. Does anybody remember whether these devices are static sensitive?
Unread 09-02-2010, 08:16
PhilBot's Avatar
AKA: Phil Malone
Re: Gyro Smoking
Phil,
If you're like me, you have trouble even seeing the traces on these boards....
I'll get out my Dino-Scope today to check on the boards...
Problem like this really kill the schedule
Phil Malone
Unread 09-02-2010, 08:17
Re: Gyro Smoking
Hey,
I don't have trouble seeing, there just isn't enough light.
Smoking potentiometer David55 Electrical 6 29-06-2006 21:25
pic: DSK Smoking Kevin Kolodziej Extra Discussion 1 27-03-2006 17:37
Camera Shorts (and starts smoking) kokodabear Programming 7 20-02-2006 20:50
smoking drill motors? quickie25 Technical Discussion 22 01-03-2004 23:32
