Go to Post If this photo doesn't tell us why a photographer is important to a team, I don't know what will. - JaneYoung [more]
Unread 18-01-2010, 18:39
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Question 2010 Wind River [HELP]
Ok so this is the first year we're using Wind River, after using LabView last year. We have all updates and can connect to the robot. We used an example provided by the FRC, the Simple Robot one i think, and can download it to the robot. But when we reboot the robot with the diver station plugged in we get green lights on 'Communication', 'Code', and 'Stop Button' but cant control the robot with the joystick. If anyone can help we would appreciate it.
cRIO Image: v19
Driver Station: Up to Date
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
Unread 18-01-2010, 19:59
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: 2010 Wind River [HELP]
If you are receiving green lights across the board it probably means that it is your code or hardware. Are you loading for release or debug? Also are you clicking the enable tab?(I have to ask) What port does the joystick/gamepad show up on? Are you using Victors or Jaguars?
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 18-01-2010, 20:13
Silly question: did you click "Enable" on the Driver Station? What does the status message in the bottom left corner of the display say?
Unread 18-01-2010, 22:36
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Are you downloading the correct executable in Window->Preferences->FIRST Downloader Preferences?
Make sure hardware is set up, for some reason the USB Hub must be plugged into the left side of the Classmate.
Unread 18-01-2010, 23:26
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
You can use the right one... just have to use the black connector.
Unread 19-01-2010, 18:21
Caboose's Avatar
AKA: James Parks
Question Re: 2010 Wind River [HELP]
For 'Team Number:' we have 587
For 'File to download' we have
<our workspace>/SimpleRobot/Debug/<whatevers here.>/SimpleRobot.out
I then build the project and click FIRST -> Download
We then restart the robot and again get green lights, and yes we do enable the robot...
Any ideas? Maybe a step-by-step tutorial?
-James
myManga
Unread 19-01-2010, 18:27
FRC #2152
Another post details the process:
http://usfirst.org/uploadedFiles/Com...ed-Rev-0.7.pdf
http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
Unread 19-01-2010, 21:27
Caboose's Avatar
AKA: James Parks
Talking Re: 2010 Wind River [HELP]
As it always happens we figured it out at the end of the day.
It had nothing to do with Wind River or the computer. What happened was when we were getting the cRIO ready for the move to it's new robot body we unplugged the HUGE cable that goes to the little blue PWM control board and plugged it back into the cRIO in the wrong port ...but we got it working now... finally...
myManga
Unread 19-01-2010, 22:01
FRC #2152
It's always the engineers' fault.
Unread 21-01-2010, 03:34
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
One thing to put on your checklist when you are having complete lack of functionality problems like that is the /load_out.txt file that is now generated on the cRIO when it boots. It basically tells you if you've forgotten a required module or plugged it into the wrong slot. It even will tell you if you accidentally bent one of the DB15 pins over (on the backplane) and the module LOOKS like it's plugged in, but there is no connection (rather difficult to debug otherwise).
You can look here for detailed information: http://firstforge.wpi.edu/sf/wiki/do...b/wiki/Loadout
Unread 21-01-2010, 07:53
This reminds me of a really bad joke a student told me once.
Q. How many programmers does it take to screw in a light bulb?
A. None. Clearly this is a hardware problem.
Mike Copioli
Unread 21-01-2010, 09:56
Caboose's Avatar
AKA: James Parks
Thumbs up Re: 2010 Wind River [HELP]
Thats's great to know. I never knew that.
myManga
Wind River Cds Team1710 C/C++ 0 22-09-2009 10:57
Uninstall Wind River Lord_Jeremy C/C++ 0 15-01-2009 15:56
SVN wind river Mr.Macdonald C/C++ 3 13-01-2009 12:40
build in wind river Pneumaticsman C/C++ 3 12-01-2009 15:54
Wind River Help BenB Programming 3 02-01-2009 21:42
