Go to Post I think being successful in FIRST is creating an environment where people can grow, learn, change, and recreate... It's about making an environment where kids feel they can be successful... in whatever discipline they choose. - ColleenShaver [more]
Unread 19-01-2010, 17:44
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Reinstall of dashboard doesn't fix camera image streaming
I'm trying to get the camera to stream images to the dashboard. Currently, this is what happens:
The code (in C++) looks like this:
                printf("in operator control\n");
		GetWatchdog().SetEnabled(false);
		AxisCamera &camera = AxisCamera::getInstance();
		camera.writeResolution(k320x240);
		camera.writeBrightness(0);
		printf("Done with camera\n");
		Wait(3.0);
		printf("done waiting\n");
which is at the top of Operator Control. The IP address of the dashboard machine is 10.15.40.5. I have updated the cRIO and also installed the LabView and dashboard updates, as well as the missing DLL.
When I run the code, I get, in the console:
in operator control
task 0x1de16ff0 (FRC_cameraTask) deleted: errno=0 (0) status=0 (0)
Done with camera
done waiting
After looking at the thread at http://www.chiefdelphi.com/forums/sh...ghlight=camera I uninstalled and then reinstalled the driver station update. This did not resolve my problem.
I can ping the camera from the cRIO's command prompt and I set up the camera using the "Setup Axis Camera" tool.
When I run the program and look at the dashboard, all that I see for the camera is a white screen.
Does anyone have any ideas why it isn't working?
Thanks.
Unread 19-01-2010, 18:35
FRC #1540
Re: Reinstall of dashboard doesn't fix camera image streaming
I got it working. The problem, I think, was that I wasn't giving the camera enough time to boot up. A Wait() at the start, or just waiting for the cRIO a while after booting, fixes this.
Unread 20-01-2010, 08:04
Ah. I saw this with a C team last year. If the cRIO boots faster than the camera, you can have the cRIO start pestering the camera for images. The camera is still in the process of booting, and has to spend time processing the images and returning errors. Doing this, meant that the camera wasn't finished booting for ~90 seconds. The solution is to slow down the camera task, especially in the error case. If you don't receive an image from the camera, or on a specific error, sleep for 250 or 500 ms before asking again.
Ideally this would be put into WPILib.
Greg McKaskle
Can we use the camera image on Dashboard this year? Jon236 Programming 1 11-01-2010 12:52
cRio doesn't re-image Lilszamora FRC Control System 3 15-02-2009 21:06
Camera Config doesn't save! comwiz7 Programming 2 20-02-2006 17:19
Fix-it window and dashboard code changes David Brinza Programming 3 28-01-2005 01:00
Image Discuss: If done. Quick Fix is here CD47-Bot Robot Showcase 2 04-03-2003 20:07
