Go to Post As it stands your design defies physics (and breaks 1 of Karthik's 2 Golden Rules). - JesseK [more]
Unread 19-01-2010, 19:06
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: 8020 Mass
Originally Posted by sgreco View Post
Yeah, each piece would be used as a rod. They make nuts that slip into the frames. You'll also notice that a 1/4 20 button head bolt will slip right into the extrusion. If you use 1x1, you can tap the end with an 1/4 20 thread, then connect it to the other piece by slipping a bolt head into the other piece and tightening it. You can tighten it by drilling a hole right behind the head of the bolt, so you can get an allen key to it. It's hrad to describe so this may not make sense. If you use Loctite it will suffice for a frame. My did it in 2008 and it worked just fine.
I think I understood. Our team has used 8020 for years, just I'm one of the few surviving people who know how to use CAD.
This is going to be fun. Whee...
I wish I could drag Inventor windows to my second monitor, would be soo much easier than flipping back and forth to see my measurements.
-Tanner
Unread 20-01-2010, 19:49
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: 8020 Mass
go to where you would edit the color- then go all the way down to material styles, then open that, then double click on aluminum 6061, it should turn bold, then the entire solid is recognized as aluminum 6061, including the mass
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 20-01-2010, 20:34
Tanner's Avatar
Re: 8020 Mass
Thanks, but as far as I know if I model a rectangle 1"x1"x12" it'll model the mass as a solid piece of Aluminum with the same volume.
-Tanner
Unread 20-01-2010, 20:38
joek's Avatar
Re: 8020 Mass
yes, you must put the thickness of the tubing into the sketch, but if you use extruded 80/20, it will do the shape
Unread 20-01-2010, 20:39
joek's Avatar
Re: 8020 Mass
you can shell stuff too. to make it a hollow piece
Unread 21-01-2010, 16:43
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: 8020 Mass
I would also verify the weight of your piece. Library components may have simplified fillets. 80-20 is a complex extrusion, some components dont model all the detail and then your weight will be off a bit.
Marie
Unread 21-01-2010, 17:33
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Re: 8020 Mass
densities in lbs per cu in:
1010 - 0.042475
1515 - 0.111917
1515 lite - 0.087167
Unread 23-01-2010, 10:24
Re: 8020 Mass
Make certain that when you are calculating mass you take density out to at least 4 decimal places - especially in an SI (millimeter -gram-second) units.
Marie
pic: What goes on those 8020 Rails?? Thermal Extra Discussion 7 10-01-2009 08:12
pic: 8020 Chain Tensioning idea Andy L Extra Discussion 12 03-11-2008 16:08
Center of Mass question Alex1072 Technical Discussion 11 26-01-2005 17:03
Mass properties in Inventor telkanuru Inventor 2 26-02-2004 21:59
Need help in Mass.? CaptainPlaid General Forum 1 16-12-2002 12:15
