Go to Post As my daughter said, you used to shut up your robot and send it away from home. Now you just suffocate it. - GaryVoshol [more]
Unread 19-01-2010, 23:24
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Think About Protecting Your Battery!
Remember, this year securing your battery on the robot is not just a good idea. It is a requirement. Make sure you have read and understand the implications of Rule <R18>. Just having a cradle for the battery to rest inside is not going to cut it. The battery needs to be velcro-ed, strapped, buckled, tied, bolted, glued, zipped, or stapled in place so that it can't fall out when (not if) the robot turns upside-down.
-dave
Unread 19-01-2010, 23:59
IBdrummer's Avatar
IBdrummer IBdrummer is offline
AKA: Beau Muniz
FRC #5492 (Winners Circle Robotics)
IBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of light
-dave
I think that is another implication about how robust the GDC wants the robots to be this year.
Unread 20-01-2010, 07:29
-dave
Can I ask for a ruling on the stapled?
Unread 20-01-2010, 11:05
Sure, if you know your team's Q&A userid.
Unread 20-01-2010, 11:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Our robot chassis was stapled (and glued) together last year, so I supposed if the box for the battery were made with that technique, and the battery itself were not stapled (or glued) into place in the robot, then Dave's fun description might be applicable.
Aren't packing peanuts (the non-edible ones) made of a foam that is similar to that used in pool noodles?
Unread 20-01-2010, 13:18
dlavery's Avatar
Curmudgeon
I just want to know how many teams will be showing up appropriately prepared with red Swingline staplers.
With TPS cover sheets properly completed.
-dave
Unread 20-01-2010, 13:28
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
-dave
TPS?
Technology Protection Systems report (I.E. how are you going to protect the tech bits in the robot from...)
Unread 20-01-2010, 14:06
Racer26 Racer26 is offline
Originally Posted by IKE View Post
TPS?
no, no, its the Bag and Tag Robot Packaging System.
Unread 20-01-2010, 14:19
-dave
OK, I'll make sure that item gets on the inspection checklist.
____Red Swingline Stapler, and staples
Question about battery placement itsme Electrical 7 11-02-2008 16:18
pic: Something to think about... CD47-Bot Extra Discussion 27 11-07-2004 02:27
Think about it Raul General Forum 8 07-04-2003 15:00
think about it E. The Kidd CD Forum Support 2 01-12-2001 22:16
One way to think about it. Joe Johnson General Forum 16 07-10-2001 21:21
