Go to Post In real life (IE when you go to apply your engineering skills to tasks in industry) there will be constraints on all sorts of things - many of which may or may not be "fair" or even "intelligent". You must learn to either work around them or use them to your advantage - preferably a bit of both. - OScubed [more]
Unread 20-01-2010, 00:28
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
WebDMA (robot tuning via a web interface) w/easy install released
WebDMA 0.2 is now available for download at http://code.google.com/p/webdma/
This is a better packaged version of WebDMA, with a few feature improvements. Of particular interest to FRC teams, I have released an installer that installs the object files for WebDMA on your robot, and copies the header files to the needed locations for Wind River. There is also a sample program installed for Wind River as well that allows you to control two motors on your robot with the web interface as a demo. All you need to do to use WebDMA on your robot is install the install package to your development computer, and then run the install program to copy the necessary object files to your robot.
While this is very easy and painfree for beginners to install and use, of course I must give you this disclaimer since a program installed by the installer writes directly to the robot to install the object file:
WARNING: The provided installer will WRITE DIRECTLY TO YOUR ROBOT and modify files on it via FTP.
While I have tested this and this works just fine for our team on our cRio with no ill effects, I cannot be held responsible for your robot. This installer is not sanctioned or associated with National Instruments, Wind River, or FIRST Robotics. In particular, this may void your warranty, render your cRio useless, and COST YOUR TEAM A LOT OF MONEY.
If you are a student: DO NOT DOWNLOAD AND INSTALL THIS ON YOUR ROBOT WITHOUT ASKING THE ADULT LEADER OF YOUR TEAM.
But seriously, it works just fine for me though. And if you have problems, let me know.
Unread 20-01-2010, 00:40
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: WebDMA (robot tuning via a web interface) w/easy install released
While I have yet to test this version out, great job! Looks like you poured in a lot of work. I hope teams find this a very valuable tool.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 31-01-2010, 02:18
virtuald's Avatar
RobotPy Guy
WebDMA 0.2.1 is now available to download. This release fixes a bug where WebDMA would only launch once when you were running your code in debug mode on the cRio. Now it should load and unload with your robot code as expected.
Download available from the WebDMA Google Code project site. http://code.google.com/p/webdma/
Unread 05-08-2010, 19:35
Dr.Bot
Posts: n/a
Does something similar exist for Vex?
Unread 06-08-2010, 12:17
virtuald's Avatar
RobotPy Guy
No idea, I have zero experience with the Vex controller. The main reason this works on a cRio is that it is controlled over an IP network and vxWorks has a semi-reasonable network stack. Add the fact that vxWorks allows multiple threads and this works quite nicely without interfering with the rest of your robot's operation.
WebDMA: Tuning your robot via a web interface (C++) virtuald Programming 15 20-01-2010 00:17
[video] Team 2423 robot controlled via a webpage virtuald Robot Showcase 7 26-04-2009 19:22
MRS 2.0 Interface for VEX released Edmund Harfmann General Forum 2 08-12-2008 15:27
Teleconferencing via Skype - Resource Sharing Made Easy Travis Hoffman General Forum 0 15-01-2008 23:41
Failure of Robot Interface Matt McNelley Technical Discussion 23 08-04-2003 21:32
