Robot code simulation on Windows box with Windriver
I was wondering if anyone had advice on the best way to develop, build, and run a program locally on a computer without downloading the program to the cRIO. Obviously the WPILibs are not setup to work without the supporting hardware resources but I wanted to setup a simulation environment so concurrent development can happen on the project. I can easily override the WPILib classes to put a debug shim layer class in between the libs and our custom code.
Windriver has a VxWorks simulator that appears to be missing from the FIRST build. Another option would be to compile for a native build using gnu toolchain. Wanted to know if there was some knowledge out there before I plowed my own road. |
Re: Robot code simulation on Windows box with Windriver
I believe this project is similar to what you are describing: http://firstforge.wpi.edu/sf/project...b_test_harness
Patches/improvements are always welcome. Note that the code in SVN doesn't work at the moment due to me changing around how I modify WPILib, but hopefully it will be less painful to import WPILib in the future. |
Thanks for the link and generous contribution to help all FRC teams be more efficient.
| Windriver 2010 Installation Windows SDK function Error | Captain Fink | C/C++ | 1 | 01-06-2010 13:52 |
| Cruch Time Help! 3 LabVIEW Tutorial Videos: State Machines; Faster Code; Simulation | LVMastery | NI LabVIEW | 11 | 09-02-2009 14:36 |
| Building WindRiver Code? | lingomaniac88 | Programming | 4 | 28-01-2009 17:09 |
| Problem debugging code with WindRiver | LinuxMercedes | Programming | 3 | 07-01-2009 11:10 |
| Open Simulation with Dashboard Provider running | Ray Gitchell | LabView and Data Acquisition | 8 | 02-02-2007 12:21 |
