Go to Post I am used to politicians getting up and being blowhards. - Steve W [more]
Unread 19-01-2010, 16:16
nadavsen2 nadavsen2 is offline
FRC #2231
nadavsen2 is an unknown quantity at this point
Pneumatics...
We are using pneumatics for the first time and i don't have any idea how
to "connect" the code with the it. Is there a manual about it or some guide?
thanks a lot
Unread 19-01-2010, 16:28
Re: Pneumatics...
FIRST publishes a Pneumatics Manual every year to get you started.
We have some pneumatic guides posted on our website to help. The Pneumatics Step-By-Step (for the cRIO Controller) has code examples.
The Fluid Power Educational Foundation has some training information.
Here's a Pneumatic Power Concepts presentation done by Raul Olivera at the Championships in 2008.
A big issue is getting yourself some fittings to use with the tubing. They are essential parts that haven't been supplied in the KOP for the last couple of years. We had a rookie team visit us last night to pickup some fittings, so they could get their pneumatic system up and running.
Unread 20-01-2010, 02:28
FRC #2231
Re: Pneumatics...
wow , thanks
Unread 20-01-2010, 08:53
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Pneumatics...
New question - same thread.
Can we use 24VDC actuated valves instead of 12VDC valves. Doesn't the cRio drive 24VDC now ?
Ed Barker
Unread 20-01-2010, 09:00
Re: Pneumatics...
Yes, you can use both 12v and 24v solenoids this year.
The wiring permitted by FIRST allows for a possible (8) 24v coils and/or up to (30) 12v coils - just not all at the same time.
One coil is one single solenoid or half a double solenoid.
Unread 20-01-2010, 09:34
ebarker's Avatar
AKA: Ed Barker
Re: Pneumatics...
wow - that opens up a whole new world of parts that are available on the shelf - at least from my suppliers.
is there any special jumpers or anything on the solenoid driver to setup to use 24VDC ?
a few things
1) great site at 358
2) didn't know allied electronics did pneumatics
3) broken link to a alliedelec page off the 358 site, it points to a page of leds
4) the fluid power site seems to have too many broken and incorrect links - someone needs to go through the site and make a punch list to send them ( in a very very nice way of course )
Ed Barker
Unread 20-01-2010, 09:43
Re: Pneumatics...
Thanks for the feedback.
I'll pass the broken link info along and it'll get fixed tonight.
The pdf documents are getting a slight rewrite based on the latest rules & code revisions too.
The Fluid Power site hasn't been well maintained for awhile, but I like to include a plug for them since they support FIRST.
The 24v change opens up 5 cases of donated solenoids I had languishing in the shop.
Unread 20-01-2010, 09:50
ebarker's Avatar
AKA: Ed Barker
Re: Pneumatics...
One more thing - I need a supplier of pneumatic solenoid valves, 3 way and 4 way, Cv 0.30 or so. Ideally it would be a single pair of wires, one solenoid, like the Festo we had a few years back. It seems to be difficult to narrow down vendors.
and one more one more thing - what is the Festo part number in this year KOP ?
Ed Barker
Unread 20-01-2010, 10:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Pneumatics...
To get 24VDC out of the solenoid breakout you put 24V from the cRIO port of the Power Distribution Board into it.
EDIT: Also I'm definitely a pneumatics newbie but I don't understand one of the concepts in the Pneumatics for Newbies guide on the Team 358 website. The guide suggests that you would be able to run a 2"x12" cylinder (38cu in. at 60PSI) off of a single accumulator (listed as 18.5 cu in @120PSI) once. While this would be true if you could evacuate all the air from the accumulator and send it into the cylinder, in actuality can't you only run a 2"x6" cylinder once at the full 60PSI? After running this cylinder once the volume of air in the accumulator would be cut in half so the pressure should be cut in half as well, right?
Unread 20-01-2010, 12:26
Lakedaimon's Avatar
Lakedaimon Lakedaimon is offline
FRC #3012 (Spartans)
Lakedaimon is an unknown quantity at this point
Re: Pneumatics...
So this explains why we have not gotten the parts to get the pneumatics system working. I thought that the fittings had just somehow been left out of our KOP last year (and also the checklist.) I was thinking we would get some this year, and was surprised and frustrated to find that they were missing again (we are a second year team this year, so we've never gotten any.) So... if anyone can give some advice on what we should buy and where is the best place to get it, it would be much appreciated!
Firmware is the most expensive thing in the universe. - Jack G. Ganssle
Unread 20-01-2010, 12:32
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Pneumatics...
If you can find a veteran team in your area. Odds are they will have lots off fittings on hand.
Unread 20-01-2010, 13:40
Re: Pneumatics...
Yes, you're quite correct. Only 18.5 cu in of air are available at 60 psi from one of the Clippards at 120psi. Unless you use the vampiric, suck 'em dry, mechanism...
I also see that there are several unfinished notes that should be fleshed out. Senioritis obviously set in - both mine and my students.
Thanks.
P.S. Ed, I'll have to check on those.
Unread 20-01-2010, 14:50
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Pneumatics...
Not receiving any push-to-connect fittings in the KoP was (for me) the same as not giving teams one official soccer ball in the KoP: a somewhat inexpensive gesture that could have alleviated most teams from having to track down a really obscure component. Anyway, after searching high and low among various suppliers online, we found that Automation Direct had the best prices on COTS push-to-connect fittings. (If you want the cheapest, just search eBay for "push to connect").
Here's links to all the various 150PSI, 1/4" tube, push-to-connect fittings that may be useful, the bold ones especially so:
Three-way Union T: http://www.automationdirect.com/adc/...Union_Tee/UT14
90 Degree Elbow: http://www.automationdirect.com/adc/...ion_Elbow/UL14
Three-way Union Y: http://www.automationdirect.com/adc/...9/Union_Y/UY14
Four-way Union Cross: http://www.automationdirect.com/adc/...ion_Cross/UX14
Straight Connector: http://www.automationdirect.com/adc/..._Straight/US14
1/4" NPT Male to Tube (Straight): http://www.automationdirect.com/adc/...dy%29/MS14-14N
1/8" NPT Male to Tube (Straight): http://www.automationdirect.com/adc/...dy%29/MS14-18N
1/8" NPT Female to Tube (Straight): http://www.automationdirect.com/adc/...aight/FS14-18N
1/4" NPT Male to Tube (Elbow): http://www.automationdirect.com/adc/...Elbow/ME14-14N
1/8" NPT Male to Tube (Elbow): http://www.automationdirect.com/adc/...Elbow/ME14-18N
1/8" NPT Male Run T: http://www.automationdirect.com/adc/..._Tee/MRT14-18N
1/8" NPT Male Branch T: http://www.automationdirect.com/adc/..._Tee/MBT14-18N
1/8" NPT Male Meter-In Flow Control Falve:* http://www.automationdirect.com/adc/...r-in/FVR14-18N
1/8" NPT Male Meter-Out Flow Control Valve:* http://www.automationdirect.com/adc/...-out/FVS14-18N
* Either meter-in (slows air into the pneumatic cylinder) or meter-out (slows air coming out of the cylinder) works, just be sure to keep it consistent. Back when push-to-connect fittings were in the Kit of Parts, teams were given meter-out fittings.
Art Dutra IV
世上无难事,只怕有心人.
Unread 20-01-2010, 17:57
Lakedaimon's Avatar
Re: Pneumatics...
Fantastic response Artdutra04, thanks!
Unread 20-01-2010, 22:47
Re: Pneumatics...
It's Festo part # VUVG-L10-B52-T-M7-1P3
Documentation
Datasheet
M7 fittings...
pneumatics edomus General Forum 8 26-02-2003 10:40
pneumatics archiver 2000 3 23-06-2002 22:58
pneumatics CD archiver 2000 2 23-06-2002 22:46
Pneumatics... archiver 2000 4 23-06-2002 22:37
Pneumatics archiver 2001 1 23-06-2002 22:36
