Go to Post they just build excellence and silently wait to deploy their creation on the unsuspecting masses - Koko Ed [more]
Unread 18-01-2010, 18:55
JohnFogarty's Avatar
AKA: @doctorfogarty
Red face So i have another problem >.<
Thanks to all who helped me with the earilier cRIO Not Working Post. I set up the Robot Project as the startup and it worked my only problem now is one joystick is controling both motors. And if i'm reading the program i made correctly it should be Right joystick controlling PWM 1 and Left controlling PWM 2 Right now it is doing only the right stick controlling both. Moving the stick forward moves 1 back and 2 forward, moving the stick back moves 1 forward and 2 back, moving it left goes both reverse, and moving it right makes them both go forward. I am trying to acheive Tank drive. If anyone has a program they could send me it would be immensly helpful.
John Fogarty
Unread 18-01-2010, 19:01
mikelowry mikelowry is offline
FRC #1771 (N.G.R.)
mikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to all
Re: So i have another problem >.<
Are you using c++?
It's been a while since I did anything with the code, but if you post yours then I can tell you what is wrong with it.
2008 Xerox Creativity Award - Championships
2009 Rockwell Automation Innovation in Control award - Peachtree
2009 GM Industrial Design Award - Palmetto
2009 Palmetto Champions <1771 2415 21>
Unread 18-01-2010, 19:10
AKA: @doctorfogarty
My bad i forgot to mention i'm using LabVIEW xD
John Fogarty
Unread 18-01-2010, 19:46
Zorkinian Zorkinian is offline
AKA: John Gilbert
FRC #0488 (Xbot)
Zorkinian is on a distinguished road
If you post a picture of the code in question, we might be able to help you out. =]
Unread 18-01-2010, 20:37
AKA: @doctorfogarty
John Fogarty
What you describe sounds like you've got Arcade Drive with the right motor running inverted from how it's supposed to be. That suggests that you aren't deploying the code that you posted pictures of.
Unread 18-01-2010, 20:57
AKA: @doctorfogarty
Yeah that's what i thought, but i went back and this is the code it deploys. idk i'm quite confused
John Fogarty
Unread 18-01-2010, 21:06
Gary.C Gary.C is offline
OUTWORK US
FRC #1323 (MadTown Robotics)
Gary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond repute
Send a message via AIM to Gary.C
Seems like you have the joysticks on arcade mode. Well on the joysticks there should be a little knob type thing. The manual says to move the z wheel on the joystick down to the [-] on both. Move the z wheel to the [+] for arcade. I had the same problem for a minute or two and then I realized you had to move the z wheel.
Gary Chahal
Webmaster & Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 18-01-2010, 23:26
One thing to keep in mind is that telop.vi is called 50 times a second by robot main. Thus, 50 times a second you are opening robot drive. If it works at all, I'd expect a lot of error messages in the diagnostics window of the driver station.
If Robot Drive VIs are only going to be used in telop, you could open robot drive in the init case of telop.vi and use feedback to save the device reference. However, this becomes cumbersome if you have a lot of devices, or if you want to access them other places (such as autonomous).
The better thing to do is put your open in begin.vi, and then set the device reference. In telop.vi, you can get the device reference and then use it.
Unread 19-01-2010, 22:07
Green2 Green2 is offline
FRC #2338
Green2 is an unknown quantity at this point
I am going to guess that the enums for the joystick are both on USB 1 (can't tell from the posted pictures). Make make sure they are pointing to the proper USB ports...
Unread 20-01-2010, 06:48
AKA: @doctorfogarty
Unhappy Re: So i have another problem >.<
they are on USB 1 and USB 2 still only one of them works, i tried the + wheel - and it did nothing, i tried changing the axis in the code...nothing changed, and i reversed the motor inverses and...still nothing
John Fogarty
Unread 20-01-2010, 10:18
You might try downloading code that has no joysticks just to be sure you aren't executing old code for some reason.
Unread 20-01-2010, 10:35
AKA: @doctorfogarty
Ok, i'll try that. Does anyone have a Tank Drive program i could use?
John Fogarty
Unread 21-01-2010, 03:45
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Try changing the controls for selecting the PWM channels and the USB channels to constants. That way we don't need to worry about them getting reset to default values.
Unread 21-01-2010, 06:08
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
From my experience, Joe's answer explains the problem. Otherwise, I don't see anything else that is wrong.
You could open all your motors/joysticks in Teleop.vi, but it gets complicated in just setting that up.
-Tanner
another festo problem Team2883 Pneumatics 4 11-02-2009 20:22
Another IR Board Problem C222 Electrical 2 13-01-2008 17:36
Problem solved but now another question Adam Y. Programming 1 03-05-2006 08:54
Got it working now theres another problem! cdennisxlx2 Programming 11 25-03-2006 21:58
Houston, we have a problem Cauê Fundraising 0 03-03-2005 11:13
