Go to Post I like this thread because it means I don't have to leave my house to find something to complain about! - PayneTrain [more]
Unread 20-01-2010, 07:41
Re: Gyro Smoking
Just a thought...The mounting holes for the board are part of the ground plane so if you have an electrical problem on the frame, you may have run a lot of current through the board. Double check your other robot wiring before you hook up the second device. The Crio chassis is also tied to the negative terminal of the battery and needs to be isolated from the frame.
Smoking potentiometer David55 Electrical 6 29-06-2006 21:25
pic: DSK Smoking Kevin Kolodziej Extra Discussion 1 27-03-2006 17:37
Camera Shorts (and starts smoking) kokodabear Programming 7 20-02-2006 20:50
smoking drill motors? quickie25 Technical Discussion 22 01-03-2004 23:32
