Re: FP Gearbox Ratio
Just a word of warning if your planning to use the FP gearboxes with the FP motors:
Some teams have found that the motor that came in the kit of parts has a 15 tooth pinion on it. The gearboxes need a 19 tooth to work properly, so if your motor has 15 tooth, it won't work with the gearboxes. |
If you have access to a CNC. You can rip the gears out of the gearbox and make new plates. It works out better since you can have your own mounting holes.
http://www.chiefdelphi.com/media/photos/34184 If anyone wants me to, I can CAD up a gearbox that uses the 15T pinion? -RC |
The reason I ask is that we have motors from a previous year (of the appropriate model number) with the 19 tooth pinion. If some teams received the motor with the 19 tooth pinion or if a COTS 19 tooth pinion is available it should be legal to use these motors.
We finally have some machining capabilities with our new shop this year (including a CNC I believe), but we are trying to avoid making anything complex until we have a chance to gain more familiarity with the machines in the offseason. |
Kevin--we made a single stage gearbox last year using the FP motor and first stage gear, and a piece of 3/8" hex shaft for the output, and some 3/8" flanged bearings. We made the the holes to mount the motor and bearings without the aid of any type of CNC or DRO device, in fact it's pretty sloppy but lasted all season.
If you need less reduction than the stock FP box gives, don't be afraid to try to make a simple gearbox using one or two stages of FP gears. |
Is there an easy way to pull the pinion off an old FP and re-fit it onto the new ones?
#8
Still needs to be COTS.....and no, there is not an easy way to get them off. It's possible to get the gears off, but it seems to require building your own strong gear puller.
#9
As Mr. Forbes posted, it is possible to get the pinion off. Teams have done this to use the FP with Banebots and AM Planetary gearboxes. Once you do get it off though I'm not sure if you could put it back onto a different motor. EDIT: As the FP with 19 tooth pinion appears to still be available from AM I think it's time for me to head over to the Q&A and see what the GDC thinks about this mess. Last edited by Vikesrock : 23-01-2010 at 01:36. |
#10
You can get the gear off with a pin punch in an arbor press, with a custom milled plate with a slot to hold it. Or, if you don't care about destroying the gear, you can crack it with a nut buster.
#11
Our motors came with the 19 tooth pinions.
| Best Gear Ratio? | Triforce11 | Motors | 3 | 22-01-2009 17:02 |
| gear ratio | Sam2197 | Technical Discussion | 19 | 21-11-2008 16:39 |
| Ramp to Ringer Ratio | Michael Corsetto | General Forum | 1 | 05-03-2007 06:26 |
| Kit Gearbox Ratio | jakep | Motors | 5 | 04-08-2006 12:58 |
| Offseason gearbox project... maybe this gearbox has helical gears? | Travis Covington | Technical Discussion | 17 | 05-06-2006 11:48 |
