Go to Post If there was no internet then somebody in FIRST would probably invent it. - Koko Ed [more]
Unread 19-01-2010, 13:20
Generator of Entropy
FRC #2973 (The Mad Rockers)
regulator on cylinder output?
I just need a sanity check - pretty sure this will work OK.
If we want a large force to extend an actuator, but don't need one to retract it, could we plumb 60 psi to the solenoid, 60 psi from the solenoid A port to the back of the cylinder, and then plumb 60 psi from the solenoid B port to the secondary regulator, drop down to 10-20 psi and then to the front of the cylinder? It allows us to use less air per stroke (out-in), and since the solenoid still sees 60 psi we don't have the pilot pressure limit on the downstream side of the regulator.
Unread 19-01-2010, 13:33
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: regulator on cylinder output?
Is there a way for the air that goes thru the low pressure regulator to the cylinder, to bleed off for the next actuation?
Unread 19-01-2010, 13:39
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
In order to regulate the retracting you would need to use a separate solenoid that is regulated down prior to it going to the solenoid.
You could do it your way, but you are still using 60 PSI all the way up to the point your 2nd regulator is (which is pass the solenoid so you would still lose some extra pressure).
But it would 'work'
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 19-01-2010, 13:41
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
You would have to use two different solenoids.
It would be easier to block the return port on the solenoid and use a light spring (like surgical tubing) to retract the cylinder.
Unread 19-01-2010, 13:55
Matt H. Matt H. is offline
Long Distance Mentor
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
You should probably consider a spring return cylinder as mentioned above. As alluded to by squirrel, you will need to do some tricky plumbing to ensure that when you pressurize the return the cylinder is at or below the reduced pressure. I'm not sure if the valve design makes this easy.
Unread 19-01-2010, 14:16
Gary,
The proportioning valves will lower the delivered air so that the return force is less but the piston still receives full 60 psi to keep it in place. The regulator may act slower than the valve approach. You would have to test the response of each one. The only advantage of the secondary regulator is slightly less air volume used.
However, this might be of interest...
<R76> “Working” air pressure on the ROBOT must be no greater than 60psi. All working air must be provided through one primary Norgen adjustable pressure regulator.
A Q&A check would give you a better answer. We have allowed more than one in the past. Specifically in the 2008 rules there were no limits on the number of regulators. 2009 had the same rules as this year.
Unread 19-01-2010, 14:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
As others have mentioned, a better option it two single acting solenoids, one plumbed for 60 psi, one plumbed for 10 psi. That or a spring return cylinder would work best. The obvious downside to the spring return being that the spring return force is going to decrease your extend force.
The problem with your proposed solution is that regulators are mostly one-way devices and don't allow unrestricted flow backwards. So you'll end up with the retract side of your piston still partially pressurized when you extend it again. Which might not be a problem for you, but wouldn't be as optimal as having two single solenoids.
Al:
I've always read that as meaning you can only have one regulator that knocks your 120 storage down to the "safe" 60 pressure, but you could have further regulators after this main regulator if you had a reason. Basically, that you were only allowed one connection from your storage battery to the entirety of your valves/cylinders/etc. Q&Aing it can't hurt, but I'd assume a secondary downstream regulator is legal until the answer came back.
Unread 19-01-2010, 14:30
Emphasis mine.
Not to nitpick, but the Festo valves are pilot operated and require a minimum of 20psi to operate (otherwise they leak).
Unread 19-01-2010, 15:56
I hadn't thought about the regulator not allowing flow in the opposite direction (or at the very least metering it). Thanks.
Has anyone priced single solenoids? It hurts already to shell out $90 for a double, I'm guessing that they're more than $45 each.
Unread 19-01-2010, 15:57
MrForbes's Avatar
AKA: Jim
CD parts swap might help...we got a few solenoid valves from a generous team back East in 2008.
Unread 19-01-2010, 19:25
Homsar66 Homsar66 is offline
AKA: Ryan
FRC #0122 (NASA Knights)
Team Role: Human Player
Homsar66 will become famous soon enough
The monnier secondary regulators DO allow pressure to flow back through them. So it probably would work.
Unread 20-01-2010, 08:05
Thanks Ryan - it will be simple enough to test and see how/if it works.
Unread 20-01-2010, 08:49
Except air from a low pressure system never backflows into a higher pressure system...
To release pressure from the low side you'll need a valve that releases to the atmospheric.
Unread 20-01-2010, 21:42
That's what the solenoid does.
When the back side is pressurized to extend, the front side vents from the actuator back through the solenoid to atmosphere. Except in this case there would be a regulator in the line.
Unread 21-01-2010, 19:31
AKA: Ryan
Yes, but after it vents the 60 psi in front of the reg then when they are equalized it will flow backwards through the reg and out the noid.
Pressure regulator Perci321 Pneumatics 13 24-01-2009 18:48
main regulator holty531 Pneumatics 2 10-02-2008 15:37
Voltage Regulator Robby Electrical 5 18-01-2005 07:50
12v regulator coreyjon Electrical 1 09-06-2004 22:08
pressure regulator blindguyinanorg Pneumatics 12 20-02-2004 08:54
