#31
Re: pic: Ramp Video
Yep Joe, Update #3 today also green-lighted it. I really look forward to seeing this design in action! Be sure to post some videos of it during competition.
#32
Thanks again! Good luck with your design. Congrats on getting the green light in Q&A!! |
#33
Re: pic: Ramp Video
The Mechanum wheels are driven, the chains drive sprokets on the ball differential, between the sprockets are steel balls that are inside a round flange with holes for the balls. The flange is attached to the drive shaft with the omni wheels. Pictures are on our wesite http://www.team1322.org/ideas.htm |
#34
Re: pic: Ramp Video
Is that the 45degree angle of the ramp? it looked to shalow, and you should build a real bump if possible because it is much harder to test with out the real thing if you know what i mean.
#35
Re: pic: Ramp Video
The video ramp is a 45 degree ramp but we had to cut the corners for the low ground clearence of the 6 inch wheels. We will be using 8 inch |
#36
Re: pic: Ramp Video
Unless the mountings can tilt in and out? |
#37
Re: pic: Ramp Video
The rear virtical strut will pivot at the frame.
#38
Re: pic: Ramp Video
[quote=joeweber;902964]The Mechanum wheels are driven, the chains drive sprokets on the ball differential, between the sprockets are steel balls that are inside a round flange with holes for the balls. The flange is attached to the drive shaft with the omni wheels. Pictures are on our wesite http://www.team1322.org/ideas.htm
I think I know the source of my confustion. I assumed the omni wheels could move independent of each other. Now that I see your ball differential drawing and photos it looks like they are attached to the same shaft so must move together. If this is true, why do you have 2 omni wheels at each location, why not just one? As always, thanks and good luck! |
#39
Re: pic: Ramp Video
It provides a smoother ride than having one single omni at each point. A number of teams have tried single; I believe most of them switched to double at some point.
| pic: SWAT 2008 Robot--Short Video Clip at http://smithvillehighrobotics.com/video.htm | SWAT1806 | Robot Showcase | 5 | 27-02-2008 14:00 |
| Ramp Driving Video | NOV8R | Robot Showcase | 14 | 13-02-2007 23:49 |
| 1583 Ramp Deployment Video | NOV8R | Robot Showcase | 9 | 11-02-2007 12:09 |
| VIDEO: Our robot VS. the ramp | Cody Carey | Robot Showcase | 9 | 09-02-2006 21:45 |
| Ramp Riot '05 Opening Video | hockeydaisy341 | Off-Season Events | 6 | 02-11-2005 14:24 |
