Go to Post You can either suck up a lot of oxygen, or you can contribute to our communal knowledge. The choice is yours. - dlavery [more]
Unread 20-01-2010, 10:15
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Re: Victor/Jag Testing set up
I understand your worries, but the motor is free spinning. We would never run it like that on a transmission or under any load. As for the fan thing, we used these countless times in underwater robotics application with amp draws pretty low, like 15 amps for a second (Like a free spinning motor).
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
pic: cRIO CAN Jag Andrew Schuetze Extra Discussion 63 25-07-2009 01:48
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
Victor::Set not working wireties C/C++ 7 28-01-2009 04:53
