Go to Post From past experience members of our team insist on never trusting gravity. - Vash [more]
Unread 20-01-2010, 08:25
Craig's Avatar
Craig Craig is offline
Drive it like YOU BUILT IT!
FRC #4976 (REBELS!)
Craig is an unknown quantity at this point
Re: Worm gears
We used that exact gear set for our winch in 2004 (Frenzy)
We were very pleased with the results. Lasted 2 regionals with no significant wear.
If it is possible to back-drive it, one robot is not nearly enough force to do it in our experience. If you were lifting 2 or 3 I suppose you'd have to try it to find out.
Founding member: Team #4976 GO REBELS!
Spent some great years with #2386
Founding Member: Team #843
Unread 20-01-2010, 10:07
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Worm gears
Worm gears are fraught with peril for FIRST teams.
Well, actually, they are fraught with peril for any application, but some times you need to face your demons!
In one off applications like FIRST robots, you really need to know what you are doing to use a worm gear (other than the one in the window motors of course).
Getting the center distances right is a harder task, managing the thrust loads, etc. etc. And don't get me STARTED on efficiency (you flush half to 2 thirds of your power right down the drain -- and that is if you do things right you can waste 90% easily without even trying! But... that is is why they are not backdrivable - so that can be a plus but...)
My advice: find another way if you can.
As for me and my house... ...I am thinking this is a job for NBD -- Nothing but Dewalts -- Worked for me and Chief Delphi in Raising the Bar, I don't see why it shouldn't work for Breakaway
Joe J.
Team #88, TJ2
Unread 20-01-2010, 10:13
Aren_Hill's Avatar
Build Nifty Things
Re: Worm gears
Originally Posted by squirrel View Post
Or a socket wrench ratchet?
We used and box end ratchet wrench in 2007 to make our lift winch non-backdrivable.
All it required was a hex of the appropriate size welded to the winch shaft, and then prodding the pawl with an allen wrench to let it back down.
worked like a charm
A guy who likes robots.
Unread 20-01-2010, 11:03
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Worm gears
It appears the door opener gears probably have better efficiency than most worm gears, because they don't have a very steep ratio, and apparently are backdriveable. The sliding tooth contact is not as efficient as the mostly direct contact of spur gears, so the efficiency must be less, thanks for pointing that out.
We had some fun with DeWalts our rookie year, and are a bit leary of them. I suppose if you are good at machining an 8mm hole in a pressed metal gear that has a 9mm minor diameter, then can get the gears pressed on the shafts (and have it survive a few regionals) without breaking they are OK, but that shaft to gear coupling problem makes me shy away from them for use with a CIM. A FP driving them should not be so bad.
Thanks for the comments!
Unread 20-01-2010, 13:56
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Worm gears
<snip
My experience is nearly universally positive. The shifters have had some problems (mostly due to programming issues that put them out of gear in autonomous) but other than that, I have been very happy with them.
Of course, I have always had access to either a good wire EDM source or a retired tool & die maker that made jewelry (figuratively) so getting things made were never an issue.
AndyMark (and to a lesser extent Banebots) has pretty much put me out of the NBD business, BUT... ...for an efficient high ratio (roughly 50:1) with a non backdriveable output, it is tough to beat it. imho.
Joe J.
Team #88, TJ2
Unread 20-01-2010, 14:15
Chris is me's Avatar
AKA: Pinecone
Re: Worm gears
I don't know much of anything about this kind of thing, but a DeWalt was one of my initial thoughts this year for hanging. It's not too heavy either, and it's stood the test of 2004. Once I figure out the easiest way to get my hands on them...
Unread 08-08-2011, 11:37
MrForbes's Avatar
AKA: Jim
Re: Worm gears
Very interesting....
http://www.andymark.com/product-p/am-0917.htm
Unread 08-08-2011, 12:14
Jared Russell's Avatar
Taking a year (mostly) off
Re: Worm gears
These were available to play with at IRI - very cool!
Just a note to those who may be wondering - these gearboxes are indeed backdriveable (I backdrove one by hand). Design accordingly
Unread 08-08-2011, 12:52
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: Worm gears
Just another thought to consider with garage door gear strength is the fact that garage doors are counterbalanced with either coil or torsion springs, so the opener is not lifting as much weight as you might think. Backdriving can be eliminated with a ratchet/pawl operated by a servo to lock the transmission in position(s).
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 08-08-2011, 21:28
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Worm gears
Good find, Jim! And, thank you for starting this thread.
I must say that a couple of things inspired this design. One was this thread, and another was the failure of my home's garage door opener this past spring. After replacing the gears in my own garage door open twice, I figured that these gears may be good to try on a FIRST robot.
Also, I recall that there was an FRC team in St. Louis who used these same gears in their drive train this year. I forget who it was.
We did some testing on these gearboxes, and found that it takes about 85-90 ft-lbs of torque to strip the plastic teeth. We actually broke the large gear hub with a previous design at 60 ft-lbs, but then we beefed up the support around the hub so that the weak link in the design was indeed the gear teeth.
We have found a few things about this design that we like:
1. It is lightweight. The entire gearbox weighs 1.1 pounds.
2. The gearbox is quiet.
3. The CIM motors are out of the way, leaving the center of the robot with plenty of room for game object pickup (if needed)
Here is a video of a 4wd mecanum system using these gearboxes.
Sincerely,
Andy B.
Unread 08-08-2011, 22:41
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: Worm gears
Andy - did you measure an efficiency?
Unread 08-08-2011, 23:31
MrForbes's Avatar
AKA: Jim
Re: Worm gears
Neat!
It appears to me that the common failure mode in garage door openers is wear due to lack of lubrication. So make sure you provide plenty of grease, and instructions to use plenty of it, with the gearboxes.
Unread 16-08-2011, 19:34
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Worm gears
Andy - We like these a lot and plan on getting some in the next month or so. Are you planning on releasing a CAD file of this at some point?
Unread 16-08-2011, 19:57
AKA: Pinecone
Re: Worm gears
Guess who's making this into an arm gearbox?
With some earlier reduction (say, an RS-775 into a CIM-U-LATOR and AM Planetary), you can easily get your robot down to arm speed.
Unread 16-08-2011, 20:36
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Worm gears
Awesome.
103 used a worm gearbox this past year for the tower (though it was not designed by us). It worked really well and the only thing that had problems were the spur gears driving the shaft that the worm was on.
Question about worm gears kajeevan General Forum 10 20-08-2008 20:39
Worm Gears chooKcha Technical Discussion 4 30-06-2007 18:12
Worm Gears FIRST JerseyKid Technical Discussion 13 18-01-2006 10:13
Looking for nylon worm gears (~64 pitch) Travis Covington Technical Discussion 3 12-03-2004 22:30
