Go to Post Our job is to play the game that the GDC gave us, not the one we think they should have given us. - Herodotus [more]
Unread 20-01-2010, 12:18
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Possible to Adjust Speed
Originally Posted by aziobro View Post
Is it legal to use more than one valve? This would allow twice the flow rate into the cylinder.
Would you have to make sure that the Cv was smaller?
Is it legal? Yes.
Do you need to lower the Cv? No.
Will it produce twice the flow? no. This is due to a number of factors including turbidity (sp?) when recombining the flows, etc. Experiment with this, as it is a good learning point in fluid dynamics.
Hint: use 'Y' connectors
___________________
- Tennyson, Ulysses
Unread 20-01-2010, 12:51
cbpetrovic's Avatar
cbpetrovic cbpetrovic is offline
AKA: Mr. P
FRC #0166 (Chop Shop)
cbpetrovic is a jewel in the roughcbpetrovic is a jewel in the roughcbpetrovic is a jewel in the rough
Send a message via AIM to cbpetrovic
Originally Posted by ligerbots View Post
Hey,
I was wondering if anybody knew of a relatively simple method of adjusting the speed or volume of air flow into the piston? Basically allowing the piston to shoot out real fast or to slowly shoot out.
Thanks for your help!
Yes, there is. Use a "Y" to connect your piston to the air source, one leg has a restrictor in it, the other does not. Use a check valve to prevent bleeding air from the "unactivated" side and there you go.
Feed air from the unrestricted side and you get a rapid deployment of the piston, and from the other side a restricted air flow reduces the speed.
Unread 22-01-2010, 12:16
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Hey,
This is quite easy to do.
1) Y-tie your exhaust ports together on your piston control valve and run it into the pressure input port (P) of a second valve (call it valve2).
2) On one output of valve2 (A or B), attach a flow control to meter the exhaust. Leave the other output port (B or A), and the exhaust ports open.
Now, when valve2 is set to the open position, the cylinder runs at full tilt (or at whatever rate the flow controls are set to on the cylinder itself, if included). When valve2 has the flow control switched in, your cylinder will "exhaust slowly", based on the flow control's setting.
Couple this with additional flow controls on either or both ends of the cylinder to adjust individual full speed 'default' flow rates in each direction (and considering the limited amount of total air we have anyway), and this should give you plenty of rate options. I've found it covers over 90% of typical FIRST multi-rate applications.
Note that many valves are "piloted", which means that they need a bit of air pressure on the input (P) port to accomplish switching so YMMV with them. IOW, depending on what valve you use for "exhaust plugging", if it is spring return or not, AND which way you default it, it may take a fraction of a second for the exhaust air to build up in front of it enough to switch the valve.
Therefore, with spring return valves I normally suggest the "unenergized" state to be the metered/restricted flow state, JUST to make sure it WILL build up enough air pressure to switch to the other state. Those valves will automatically return to the unenergized state (regardless of coil signal !) once the pressure drops enough. In this app, that is OK.
BTW, you COULD try to meter the source with a second valve, but if you try it and set the restricted flow rate too low, you will find under some pneumatics plumbing circumstances (and valve choices) the directional valve will fail to respond due to insufficient pilot pressure (or on spring return valves, it can go the WRONG WAY!). Switching a flow control in/out of the EXHAUST plumbing instead overcomes this problem.
Does this make sense?
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 28-01-2010, 11:36
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
What if you used a servo that will turn CW or CCW without stops? You could use a piece of tubing to match the servo output and the flow control knob.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 28-01-2010, 12:25
kmcclary's Avatar
Rookie Year: 1994
Not sure of this year's rules regarding servos. (CAN you use stronger ones THIS season, or continuous rotation servos? You couldn't in previous years.)
Bear in mind that the kit regulators take a LOT torque to turn. Probably way too much for the basic kit servo.
Now you CAN easily make a servo in software with a pressure regulator, a window motor, a 10-turn potentiometer, and TWO pressure transducers (1 for output, 1 for SYSTEM pressure, to make sure you CAN reach it before trying).
In addition to a simple closed loop servo routine in software, you also need to do a few other things:
(a) put both software limits to the pot AND a mechanical friction/slip clutch between the motor and the pot/regulator set, to keep from breaking either one should the motor or software go crazy and attempt to turn it too far in either direction.
(b) monitor the full system pressure as well, to disable the servo routine when the system has insufficient pressure. Otherwise, you will "polarize" the servo wide open, trying to get it to a setting you simply can't reach.
But there are simpler methods.
Example - Create a Buffered Supply Tank, at any programmable pressure.
Use a center-blocked valve (or a pair of kit valves), two flow regulators, a pressure transducer, one Clippard tank, and software. Software is similar to the compressor routine. In this case though, whenever it is out of range EITHER way, pulse one or the other valve coil to either fill or drain the tank until it reaches the desired pressure.
One flow regulator controls the tank FILL rate (NEARLY wide open), while the other controls the BLEED-OFF (probably a fairly low setting, to prevent TOO much air waste from a user's "setting indecisions" ). A software variable now determines the tank's desired "set" pressure, and it "automagically tracks it".
Simpler: Monitor the cylinder's pressure with a transducer. When the cylinder reaches the desired force, just cut off its supply! (Again, use a center-plugged [center-off] valve.)
FYI, a center plugged valve is one of the order options for valve parts in the familiar KoP SMC SY3000 series. See the SMC datasheets for more info.
- Keith
Unread 28-01-2010, 12:35
We are still limited in power (except we are allowed to gang up an unlimited number of them), but as long as they are COTS and unmodified, you can use continuous rotation servos.
<R52> Motors specifically permitted on 2010 FRC ROBOTS include:
A. All motors, actuators, and servos listed in the 2010 KOP,
B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the KOP),
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Is it legal to adjust CIM's timming? Capt. Quirk Motors 6 16-01-2008 07:35
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
Possible to do multi-speed transmission with v-belt? Squirrelrock Motors 15 13-12-2005 14:44
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
