Go to Post Think Tolerant. - petek [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #121   Spotlight this post!
Unread 20-01-2010, 10:12
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Re: Breakaway Discussion
You might want to think about re-inforceing your bumpers to take a hit from above. Just saw 120 pounds of bot coming down a bump. Looks scary. If your bot is passing by at the wrong time , i could see some bumpers getting sheared off.
  #122   Spotlight this post!
Unread 20-01-2010, 12:38
AlexSortor AlexSortor is offline
FRC #2557
AlexSortor is an unknown quantity at this point
Originally Posted by 2945Robotics View Post
thanks, that helps tremendously
I dont believe i have, lolz, i actually only saw "Team Update #1"
  #123   Spotlight this post!
Unread 20-01-2010, 12:56
Means you need to look at the updates page again. They're up to #3, and #4 is due out Friday.
  #124   Spotlight this post!
Unread 20-01-2010, 13:28
vic burg's Avatar
vic burg vic burg is offline
Alumni, Mentor, & AmeriCorps VISTA
AKA: Captain Obvious
vic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to behold
What?! Oh crap I need to find those.... I only knew about 1. My computer must be hiding these from me.
RoboColts--Hallandale Elementary
--Thanks goes out to Cody C for making me ^^this^^ user bar!!!!
Nuts and Bolts help the world go 'round.... They also keep us all together. Including the Robots we build. -vic burg
I have been dubbed an honorary member of 1902 and 744 (by the members).
And yes, I am in the habit of collecting team t-shirts.
  #125   Spotlight this post!
Unread 20-01-2010, 14:08
FRC #0910
I understand the answer to the question the way it is written, http://forums.usfirst.org/showthread.php?t=13940 , but are you not able to change robot size if you are in touch with tower? Also understanding that you are not protected during this change. What, maybe i don't understand gdc answer. Can anybody clear this up for me?
  #126   Spotlight this post!
Unread 20-01-2010, 14:57
I had to think about this, and it's both sides' fault for that one. I believe that the question referred to expanding and contracting the frame, which is specifically disallowed.
Anything above the frame perimeter/not affecting the frame perimeter, no big deal.
  #127   Spotlight this post!
Unread 20-01-2010, 15:02
KrakatoaCoo's Avatar
KrakatoaCoo KrakatoaCoo is offline
UNRegistered User
FRC #0348 (Norwell Robotics)
Team Role: Animator
KrakatoaCoo is an unknown quantity at this point
i love this game because it seems there are a lot more challenges than last year. The changeable bumpers are a really great idea because I was always confused as to which robot was on which alliance.
Nerds aplenty?.....
  #128   Spotlight this post!
Unread 20-01-2010, 15:28
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
the way I read it is that you can not make the perimeter of the robot wider or narrower. The Frame perimeter cannot chage even during the FINALE (R11). The question that I have is can the height change any time before the FINALE? Below is the definition of the NORMAL Configuration of the robot and it seems to say that the once the robot is placed on the field for the MATCH, it cannot change shape until the FINALE period. I know that the allowed NORMAL configuration height is up to 60" but can it change during the game? Or, is this statement only saying that the starting configuration must be identicle for a given MATCH (like the playoff rounds when it's the best of 3 for the match).
NORMAL CONFIGURATION – The physical configuration and orientation of the ROBOT when the MATCH is started. This is the state of the ROBOT immediately before being enabled by the Field Management System, before the ROBOT takes any actions, deploys any mechanisms, or moves away from the starting location. This configuration is static, and does not change during a single MATCH (although it may change from MATCH to MATCH).
  #129   Spotlight this post!
Unread 20-01-2010, 16:25
You are allowed to expand up to the Finale Configuration at any time provided that you contact the Tower or that it's the Finale period. I would encourage you to read <G30> carefully, particularly <G30-C>.
  #130   Spotlight this post!
Unread 20-01-2010, 17:51
JHSmentor's Avatar
FRC #3210 (Falcons)
Hmmm - yeah, it seems that you are correct the way it's written - but it sounds like risky business to me. if you got pushed off/away from the tower while you were extended then you risk getting a penalty if this happens prior to the Finale period. I personally can't think of a reason to do this or where it might be beneficial - but I'm sure i'm not thinking far enough outside the box for various possibilities.
  #131   Spotlight this post!
Unread 20-01-2010, 17:52
Chris is me's Avatar
AKA: Pinecone
If you're pushed away, your opponents would be forcing you to incur a penalty, which isn't allowed.
  #132   Spotlight this post!
Unread 20-01-2010, 17:53
If you're pushed away by an opponent, <G13> protects you from getting a penalty. (Though once they've stopped pushing, you need to either get back to the tower or get back to normal configuration.)
I can think of a reason or two to extend like that. Slow hanger is one reason; there are others.
Breakaway Logo WilliPri General Forum 2 09-01-2010 13:00
Breakaway Manual Test markulrich Rules/Strategy 0 09-01-2010 12:22
New (breakaway) team, very nervous... synth3tk General Forum 9 22-02-2008 23:42
Extra Discussion for Picture Discussion Ianworld Robot Showcase 1 31-01-2005 01:28
Repeated discussion archiver 2000 0 23-06-2002 23:56
