Go to Post High heels on a Segway takes quite a bit of adjustment - as I learned the hard way. - Jessica Boucher [more]
Unread 19-01-2010, 18:26
neilpatel92's Avatar
neilpatel92 neilpatel92 is offline
Student Leader of Team 2876
AKA: Neil Patel
FRC #2876 (Devil Bots)
neilpatel92 is an unknown quantity at this point
Send a message via Yahoo to neilpatel92
Exclamation Dangers of High Speed Pneumatic Gun
I'm looking for advice from veteran teams and mentors on pneumatics since we are a 2nd year team.
Our team was planning on using a high speed pneumatic gun to hit the soccer balls with enough velocity so they would go over the ramp.
However recently we discovered by calling Bimba that after speeds of 20 in./s on a pneumatic cylinder, the cylinder will start to break down.
We've done the physics calculations and we need the speed of the pneumatic piston to be atleast 5 m/s to use it as a gun. Obviously we need more speed for the gun design, but we don't want the gun to break down in the middle of a game either.
Is there any way that we can prevent damage on these pistons, and slow the pistons at certain points during the shot to prevent damage? Is there any way to prevent damage completely?
Or should we just scrap the idea of a pneumatic gun?
_Neil
Unread 19-01-2010, 20:42
Re: Dangers of High Speed Pneumatic Gun
_Neil
Don't go fully pneumatic. Use the cylinder to swing a kicker bar.
Let r be a radius, L be a linear speed, and w be a rotational speed (technically it should be lower-case omega, but w is close).
L = r*w. Let's say that you can get a linear speed of 5 units/second out of the cylinder. You attach it close to a pivot of a kicker (let's say 5 units away from the pivot).
w is now L/r, in this case 1 radian/second.
The other end is supposed to be traveling at 20 linear units/second, let's say.
20 = r*1. You need a 20-unit long kicking device.
Do you see what I'm getting at here? Use a swinging arm and design the placement carefully, and you can get the same effect as a pneumatic cylinder going straight in at much higher speeds.
Unread 19-01-2010, 20:43
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Think along different lines. You already got your answer on how fast the cylinders can go (and here's a hint - you don't have the volume or the flow rate to get anywhere near that....).
So now you need to look at how much flow rate you DO have, how much pressure and volume you DO have, and you can turn a shorter stroke into a longer one.
Hint 1: Mechanical Advantage.
Hint 2: Think lever arm.
Unread 19-01-2010, 21:16
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I'm not a mechanical engineer, but here's what I've been pondering for the last few days. Perhaps someone who really knows can confirm or refute my hypothesis.
For a given pressure, the force you get from an actuator is proportional to the area of that actuator. The speed is inversely proportional to the volume of the actuator. You can trade force for speed with a lever arm of some sort, but that is exactly what a smaller bore size does. You can quadruple your force by using a 2x larger bore size, but that reduces your speed by 4x. In short, the mechanical power of a pneumatic actuator is limited by the size of the tube and the air pressure. Both of these are dictated by the rules, as far as I understand.
If pneumatics alone can't do it, then a pure lever arm won't help. A carefully crafted kicking device might be able to do a better job than a straight pneumatic puncher, but only because it makes better use of the available power.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 19-01-2010, 22:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Somewhere on my web page I have a picture of my hand with a nail in it, the result of slightly careless use of a high speed pneumatic (nail) gun.
As for kicking the ball....there are some threads on pnuematic kickers, you might want to read them
http://www.chiefdelphi.com/forums/sh...ad.php?t=80534
http://www.chiefdelphi.com/forums/sh...ad.php?t=80176
http://www.chiefdelphi.com/forums/sh...ad.php?t=80474
http://www.chiefdelphi.com/forums/sh...ad.php?t=80400
Unread 20-01-2010, 12:47
AKA: Neil Patel
Smile Re: Dangers of High Speed Pneumatic Gun
Thanks Everyone!
Seems like there is no way to fix this design from the replies I have gotten so I guess the idea of a high speed pneumatic gun should be thrown in the trash.
I'll keep on checking for replies but I think our team will move on to another concept; maybe, the kicker (pneumatic piston attached to lever arm) as most people here recommended.
Thanks once again,
Neil Patel
Unread 25-01-2010, 09:10
sparks-1784 sparks-1784 is offline
Lance Stronk
FRC #1784 (Litchbots)
sparks-1784 is on a distinguished road
A team used a pneumatic 'gun' in competition in 2008. That competition required moving something similar to a medicine ball. I don't remember the team number, but they rigged a parallel arrangement of small pneumatic cylinders (and mechanically connected in series) and used valve timing to accelerate the medicine ball. The cylinders were small to obtain higher speeds from the available flow rate. Pretty interesting design.
I would expect that something like this would work for a kicker without any mechanical advantage (read lever arm).
Unread 29-01-2010, 12:04
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
So who thinks the FIRST safety inspectors will evaluate the Bimba guideline of 20 in/second and potentially disqualify robots because of it?
I've see a lot of videos and pictures of pistons tied to kicking legs during kicking motion and I have yet to see one that seemed like the piston was traveling less than 50" per second for a long distance kick. Getting 20:1 or 30:1 foot travel versus piston travel ratio is tricky especially in robots that are only 17" tall. (I think kicking hard over long distance is on the order of 40 ft/sec.)
Disconnecting the piston stroke from a kicking motion is feasible to keep the piston under the speed limit and it could be a valuable undertaking depending on whether this "20 in/second" is going to be perceived as a safety issue.
Personally, I think I am much more concerned about designs that are storing hundreds of pound-feet of energy in unrated/unqualified elastics as that would seem to be much more dangerous than speed violations on a pneumatic piston. But then again, I'm not an actuary.
I'm only a second year guy- any wise sages out there have any suggestions?
Unread 29-01-2010, 12:28
Electrical Engineer
Rookie Year: 1995
Originally Posted by boomergeek View Post
So who thinks the FIRST safety inspectors will evaluate the Bimba guideline of 20 in/second and potentially disqualify robots because of it?...
Dick,
The UL safety inspectors only hand out an award. The robot inspectors are the enforcement arm for this situation.
Most of us read CD regularly...
I'm going to refer you to this post I made.
Put yourself in our shoes. What would you do? Could you look yourself in the mirror if a student gets hurt?
What do you think?
Mike
Mike Betts
As easy as 355/113...
Unread 29-01-2010, 12:29
Would you be willing to share with other teams what these physics calculations were, so others can learn from them?
Thank you.
Unread 29-01-2010, 12:30
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Edit: Mike Betts covered it.
Al or Mike Can this even be tested at a regional and how would this be done?
Unread 29-01-2010, 12:39
IMHO it is actually rather hard to travel 20in per second we use a 4'' cylinder preloaded we would have to actuate this in quicker then 1/5 of a second...
A preloaded cylinder that is vented to atmosphere on the opposite side and that is restrained and released with a mechanical latch can easily exceed 20 ips by a large margin.
Many youtube videos clearly show speeds exceeding 20ips.
Unread 29-01-2010, 12:45
Electrical Engineer
Rookie Year: 1995
Originally Posted by Jones571 View Post
... Al or Mike Can this even be tested at a regional and how would this be done?
Corey,
I have to think about it. I'm not sure that it is possible if you use a 1/8" NPT to vent...
Regards,
Mike
Mike Betts
Unread 29-01-2010, 12:49
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
how exactly are you reaching this conclusion? I find it rather hard to calculate this actual IPS on youtube videos.
Unread 29-01-2010, 12:50
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by Mike Betts View Post
Corey,
Regards,
Mike
I believe that only valves are limited by the 1/8" NPT port, not cylinders.
___________________
- Tennyson, Ulysses
Pneumatic Actuator Speed? WorkingFromHome Pneumatics 3 20-01-2010 00:09
High Speed 3-Fingered Hand EricVanWyk Chit-Chat 4 26-08-2009 18:25
The Dangers of Being Right (a lot) IKE Chit-Chat 14 17-06-2009 18:20
pneumatic potato gun i made vivek16 Chit-Chat 22 26-08-2007 18:49
