Go to Post The programmers tend to get less credit than they deserve, but the robot wouldn't run if we weren't there. :) - IMDWalrus [more]
Unread 20-01-2010, 14:04
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Re: Drive Speeds
Our time is actually going for about 3meter/second (about 10feet/second) with a 16:1 gear...
We think it is more important to be able to maneuver around the field the best we can rather than speed... Though speed is always nice, but since each part of the field is about 17X27 feet it will be hard to accelerate, keeping in mind that acceleration going both ways. Which means takes time to build up speed and to slow down.
So basically a robot that is planned to move just vertically in the field will have 27feet tops to accelerate, not to mention that it also has to slow down otherwise the motors will burn down if you will turn them over and over just in a second. So even 15feet/second is a high speed since most likely you will never get to this speed during a match without burning the motors. Unless your robot goes in the tunnel and the driver is experienced enough to get in it without slowing down.
Also i don't know if you tried it but in my opinion if you will try to pass the bump with 15feet/second you will most likely tip over or your robot will get such a strike that will shake all the structure.
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Normalizing motor speeds using Arcade Drive in Labview rsisk NI LabVIEW 9 28-08-2009 20:56
Speeds JessicaM29 Technical Discussion 3 08-01-2008 20:48
Robot Speeds Conor Ryan Technical Discussion 12 17-07-2005 23:45
Internet speeds Ryan M. Chit-Chat 33 08-09-2004 09:25
Robot Speeds - Opinions sought archiver 2000 31 23-06-2002 23:04
