Go to Post Instead of "Team XXXX graciously accepts" how about just a big "yeaaaahhhhh!" ? - sanddrag [more]
Unread 20-01-2010, 10:41
StorminNormin StorminNormin is offline
FRC #2181
StorminNormin is an unknown quantity at this point
Contradicting dimensions?
In the specs sheet, the tunnel dimensions are said to be 32.5" by 16.5". However, under section 6.2.4, the dimensions are 36" by 18".
Does anyone know which of the dimensions are correct?
Unread 20-01-2010, 10:42
EricH EricH is online now
Re: Contradicting dimensions?
In Update #3, the GDC ruled that the drawings take precedence over the Manual for determining dimensions of field components.
Unread 20-01-2010, 10:52
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
I find it highly inexcusable to have different measurements in different documents. I would have hoped FIRST actually read and looked over that kind of stuff.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 20-01-2010, 11:52
Jordan2389Diaz's Avatar
Jordan2389Diaz Jordan2389Diaz is offline
Grant me your power...Verto
FRC #2389 (Pirate Robotics)
Team Role: Tactician
Jordan2389Diaz can only hope to improve
If you read the manual you will find no contradicting dimensions.
Lord is my Shepherd I shall not want-Psalms 23
Unread 20-01-2010, 11:53
What we're talking about is the fact that the Manual says one thing and the drawings say another thing. The ruling from the GDC is that in this case, the drawings take precedence over the Manual.
Unread 20-01-2010, 12:01
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
It's too bad because the drawings are pretty poor
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 20-01-2010, 13:19
tomgee4me tomgee4me is offline
FRC #3323
tomgee4me is an unknown quantity at this point
OK. I just read a bunch of drawings and here's what I think. First, you may have misread DWG FE-10043-01, the side panel is 16.5x32.5. The 32.5" is the dimension that goes in the direction of the length of the tunnel (but not the total length), not the width. 16.5" is indeed the height of the tunnel before it is installed onto the base of the tower. The base of the tower has a 1.5x3.0" Aluminum U-channel that the tunnel sits on top of. Therefore, 16.5+1.5=18" total height. The width is easier. The top panel of the tunnel is 37" wide and sits on top of the 2 side panels (which are 1/2" plywood). Therefore, total width is 37-1=36". Thus giving the final dimension of !8" high by 36" wide for the opening of the tunnel.
Hope this helps. Rookie Mentor for Potential Energy Team #3323.
Unread 20-01-2010, 13:31
Racer26 Racer26 is offline
+1 to this sentiment. I always have had difficulty determining measurements on the FRC Field Drawings.
When we do drawings of our drive units and such we always dimension each thing back to 1 edge of the item in the X direction and likewise for the Y. It makes it easy to determine things. The FRC field drawings often leave you doing math to figure out where stuff is supposed to be.
Unread 20-01-2010, 14:23
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
When you do Ordinal dimensions (back to a single edge in X and Y) you are implying a different set of tolerances than the typical dimensioning you will get from FIRST drawings. I do wish they would give us higher resolution PDFs, or even better DWG/DXF or solid files. I wonder how many people simultaneously recreated the fields in various cad packages this year.
Also note that PTC was planning on releasing Pro/E models of the field, so you can always take measurements from that.
If you want to know way too much about dimensions, pick up a copy of ANSI/ASME Y14.5-2009 (I have a copy of the 1978 version that I got for a buck).
Unread 20-01-2010, 14:46
To be honest, I would be happy if they just put more dimensions on. They put so few on that they leave us guessing and doing math on alot of things when they could have easily stuck a dimension in.
Unread 20-01-2010, 15:19
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
I have yet to see a single drawing from FIRST that does not suck. I've seen high school kids produce more complete and easier to read drawings. It's not as though the field has a lot of (or any) complex geometry to dimension...
Team 1538 / The Holy Cows, 2005-2016
Unread 20-01-2010, 15:21
Don Wright's Avatar
FRC #0469
It's the lack of dimensions (or dimensioning that is stupid like to the edge of a hole) that is the frustrating part. When you have to spend 2 hours going through all the drawings adding the length of all the pieces up just to get some very basic, critical dimensions of the field pieces, it's quite frustrating.
And then you do all that and you build a ball return chute that is to "spec" (even though the specs are not really available on the actual positioning of the chute on the field) to the best you can do to their "competition field" drawings and the returned balls continually bounce off the tower top bar...it's quite frustrating...
And then the field you had parents and students work a week building per the "low cost" field drawings and you find that parts of it are off not by fractions of an inch, but by inches (because the drawings are wrong), FIRST quickly becomes the low bar by telling students "Your drawings for parts at least must be better than FIRST drawings..."
It's quite sad actually... Oh well...at least they got the KOP right...oh...wait...
Product Manager
Unread 20-01-2010, 15:37
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Same in the 'real world'... I deal almost daily with house plans & missing dimensions, or dimensions that don't add up.
Speaking of which, the TRIDENT, GE-10010. Page one - Item#5 (part GE-10011), is dimensioned as 1" x 48, but on page 2 it is 1" x 36"
Has anyone seen a revision or update to correct this?
Unread 20-01-2010, 16:43
Andy A. Andy A. is offline
Getting old
FRC #0095
It is, unfortunately, pretty much the norm in any industry.
Consider any document from FIRST to be uncontrolled, and always keep an eye out for clarifications. If the hard copy is more then a week old, it's probably out of date and needs to be replaced. You can always make corrections by hand, but I'd rather just redownload and reprint. Corrections and errata sheets should be placed before the body of the document.
Welcome to industry.
Unread 20-01-2010, 16:51
FRC #1405
Yeah, I am in the Industry where we use documents to build and of course, we are humans and make errors. But, in this case I still feel it is highly inexcusable. FIRST pays some engineers to design the game and documents. They know, 1800+ teams need those documents to build what FIRST has designed. How is it possible that there can be different dimensions in different documents, AND have totally WRONG dimensions in the documents at first then update the later after a week in a team update? It is embarrassing.
Tower Dimensions Kpchem General Forum 10 10-01-2010 15:42
Stinger Dimensions Wolf Rules/Strategy 3 08-01-2007 21:24
Dimensions Andrewpbhs Technical Discussion 3 04-12-2006 18:48
Dimensions Stormhammer Rules/Strategy 3 10-01-2005 02:40
Field Dimensions archiver 2000 11 23-06-2002 22:27
