Re: Frame
my thought is if u can reduce the chance of tipping it worth the time to look into it, hitting it at any angle greatly increase the the bot to flip
Re: Frame
Just be careful when using a suspension on wheels that are powered by chain - if there is too much play in the suspension and the chain is stationary on the other end, you can end up messing up your tension when you hit a bump (in the worst case, you could even throw a chain).
Re: Frame
true but i have that all figured out
Re: Frame
depending on how it works and when, you could actually increase your chance of tipping by causing a sudden shift in the robots center of gravity. of course, this is something you could flush out through testing. |
Re: Frame
You would probably be best served by applying all the technical know-how you've got to keeping the Center of Gravity (CoG) as low and centrally located as possible. The benefits of this will probably far exceed those of a fancy suspension, especially one that you aren't actually constructing right now.
Re: Frame
The lesson here is that I should not base my entire opinion on a single data point. ![]() |
#7
Re: Frame
How about pneumatic tires (aside from perhaps having too much traction)?
| pic: 48 Frame | Travis Hoffman | Extra Discussion | 6 | 26-01-2008 23:14 |
| pic: Frame is | falconmaster | Extra Discussion | 1 | 17-01-2008 23:11 |
| Steel Frame? | gburlison | Technical Discussion | 20 | 18-12-2007 16:56 |
| Frame Dragging | Wetzel | Math and Science | 0 | 22-10-2004 17:10 |
| Voltage on Frame | Greg | Electrical | 31 | 02-03-2004 13:49 |
