Go to Post It's rather simple: you start with a block of solid and remove material until you just have the robot left. Kind of like making a sandcastle. Only harder. - petek [more]
Unread 20-01-2010, 14:31
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
Re: Refnum Defining
Originally Posted by Doug Norman View Post
Because the RefNum Get is outside the case structure, it seems it should be getting called - and the error makes me think it is. One thing to try might be to actually make a copy of the "Sensor" text constant wired to the RefNum Set, and wire that into the RefNum Get. This would be just to make sure the names are identical and there isn't some hidden or nonprintable text.
This is good advice, but I've tried this too! It didn't seem to fix the problem.
Attached is my code and a picture of the error message.
refnum registry location Wendy Holladay NI LabVIEW 1 17-01-2010 22:11
Defining a joystick dr_jack3l National Instruments LabVIEW and Data Acquisition 1 12-02-2009 09:59
Defining First code? mormannoob Programming 4 17-01-2008 23:36
Defining Leadership Bomberofdoom General Forum 8 17-09-2007 14:58
Defining file name? Mike Programming 2 08-02-2006 17:28
