Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 20-01-2010, 16:01
MrWibbles's Avatar
MrWibbles MrWibbles is offline
Wibbly-Wobbly User
AKA: Adam S
FRC #2877 (Ligerbots)
MrWibbles is an unknown quantity at this point
Live video compression?
We want to have the robot send the camera's image, live, to the Classmate, but we're worried about bandwidth. What algorithms/formats should we use for compression? Is there anything in Labview for it?
Thanks in advance, AdamS
Unread 20-01-2010, 16:19
Re: Live video compression?
Is there something wrong with the camera image that is sent to the dashboard by the default code?
Unread 21-01-2010, 14:09
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
We use WindRiver and C++ and looking through the code there is a member function to set the compression automagically. I'm not sure how well it works though. I know for sure that the camera is slow when it's not compressed (the default code does not appear to compress the image at all). We may get a whopping 5 fps if we're lucky... But look around, there should be a simple way to do it.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 21-01-2010, 14:34
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
I don't know a ton about the vision system, but I noticed last year with the analyzer tool that the part of the video processing that took the longest was a VI that converted the jpeg provided by the camera into a character matrix to be used by the image processing VIs. When that was going on we only got a few FPS reliably as well. If you didn't need to image process (only wanted to look at it) I suppose that conversion would never need to happen. I'm not sure if the video it sends to the dashboard is the raw jpeg or the matrix, but either way it might be waiting for that conversion to finish.
Anyone have a better idea of exactly what it does?
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 21-01-2010, 16:25
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The PCVideoServer simply forwards the jpegs that were compressed by the camera. They are not recompressed and they are not sent raw. Your best bet is to adjust the compression / image size that the camera is sending, not trying to recompress on the cRIO.
Live Streaming Video whosdadog FRC Control System 7 14-01-2010 18:36
Live Video on Dashboard writchie Programming 23 28-03-2009 01:14
Live Video Setup CHSboy Programming 2 18-03-2009 15:36
New Video Blog Entry: "Video from Live LabVIEW Session for FRC Competitors in Toronto LVMastery NI LabVIEW 0 13-12-2008 08:09
Live video with Kit Camera BobcatProgramer Electrical 10 11-01-2005 10:43
