Thread Tools |
Rating:
Display Modes |
AXIS 206 Camera not working
The AXIS 206 camera is not giving us any video. Our Driver Station is fully updated (compass in the lower right corner), we made no alterations to the basic camera code, but we are not receiving any video from it.
Re: AXIS 206 Camera not working
The other thing to check is that your camera has been setup with the correct account and password. Also be sure to check the Diagnostics tab on the DS as it will display errors thrown by the robot and may help with debugging.
Greg McKaskle |
Please refer to http://www.chiefdelphi.com/forums/sh...ad.php?t=79935 post #68. Hope this helps.
- Bryce |
Is there a solution for LabVIEW? We've updated the Driver Station with the mandatory update, the dashboard has the compass, but we get no link lights or video with 3 different crossover cables plugged into port 2(at different times of course
) We have also tried several different methods to run camera code, but it just doesn't work. Help please! |
Can you describe the colored light around the camera lens?
It should be steady green. If it looks different, it could help determine what is going on. Greg McKaskle |
- Bryce |
#7
Thanks for the reply, we got a link today with another crossover cable(we must have been making them wrong
) but we still aren't getting an image. We got the motors and some servos working. I don't think it was a reflashing image because we tried with v19 a few times. Yes, the link lights are the two orange and green lights on the back and the ring on front takes a while to change from orange to green when we run last year's Servo Camera Example, Otherwise on the default framework, it stays orange. On the default code we get a -44003 occurred at Camera.lvlib: Issue HTTP request with Authentication.vi >>Camera.lvlib:Read JPG.vi>>Camea.lvlib: Aquire Image.vi:1 error. Any ideas?:edit: The ring just turned green on the camera. Last edited by Argon27 : 22-01-2010 at 20:45. Reason: Update |
#8
these are simple solutions but they worked for us, make sure the at least one account on the camera has the username FRC and password FRC. make sure the camera is plugged into cRIO port 2. and if all else fails run the update on the DS again and flash the cRIO with the base code. i know im a rookie this year but just thought i'd try and help.
oh! and also check your IP address on the camera it works if you set it up with the example 192.168.0.90. |
#9
Bet your Dashboard isn't the correct one.
Take a look at these pictures to see if you have the wrong Dashboard. |
#10
Thanks, my team is a rookie team this year too!(except for me
) You really got yours working Andrew? We've tried and tried again with everything you just listed. I think we might just enlist one of the other local teams to help. (Even though the next closest team is an hour away *sigh* ) Thanks, please keep thinking. |
#12
og! one more thing to try haha. unpower the camera then hold the button and while holding the button down turn it on, wait for the orange or yellow light to come up then re-IP the camera. this resets all the settings on the camera so just in case a wrong number or setting was set. let me know how it goes!
#13
Finally, make sure that the camera doesn't have its reset button pressed against the robot frame or anything else that will cause it to continually reboot/reset. Greg McKaskle |
#14
yes i agree, but the -44003 error i wouldn't worry about. We have our camera up and we still get that error sometimes but there is no issue with the camera or the camera finding the targets.
| Axis 206 cam frame rate | yoavh360 | Electrical | 11 | 23-01-2010 21:45 |
| About the 206 Axis Camera | yoavh360 | Electrical | 8 | 18-01-2010 15:14 |
| Axis 206 Web Camera no longer in production | Ragnarokae | Kit & Additional Hardware | 12 | 10-01-2010 15:59 |
| Programing servo in Axis camera 206 | frcchile | NI LabVIEW | 6 | 18-01-2009 08:53 |
| 3ds Max Z-Axis not working! | arbaard | 3D Animation and Competition | 5 | 20-09-2007 20:26 |
