Go to Post Know what really grinds my gears? Metal Shavings. - Briansmithtown [more]
Unread 20-01-2010, 17:25
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
gyroscope problems
I am having problems figuring out how the gyroscope connects to the rest of the system. If anyone has any links to manuals and documents about this, or has information that they can type out, please post.
Unread 20-01-2010, 18:57
WGRAY WGRAY is offline
FRC #2027
WGRAY is an unknown quantity at this point
Re: gyroscope problems
In Labview , go to examples, you should see the gyro example, open it and then open the gyro example vi. the front panel has a wiring diagram for the gyro.
Unread 20-01-2010, 19:00
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Have you tried the 2010 FIRST sensor manual? You can find it on this page, just scroll down to section 8 and you should see it.
Hope that helps!
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 20-01-2010, 23:17
Team Role: Student
I looked in the sensor manual and it only had technical information. BTW, I don't have LabView installed.
Unread 23-01-2010, 10:31
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
What language are you planning to program in?
Unread 23-01-2010, 11:55
Team Role: Student
Most likely LabView, but it's not installed on my personal computer.
Unread 23-01-2010, 17:35
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You should install it on every computer you could use to program. It takes a few hours, so installing it will take a long time.
The sensor should have a +5, GND, and signal/output pins. Take a PWM cable (3 pins), and cut off the end with the female connector that is long enough to connect from the gyro mounting point to the cRio analog board plus a little extra. Strip the three wires, connect the black to GND, red to +5, and white to SIG.
We generally put our gyros in a small project box and attach them to the robot with velcro.
As for software, the only thing you need to know is the volts per degree per second of the gyro, which can be calculated. I would guess that the sensor manual might tell you that, but I didn't read the sensor manual so I don't know for sure. If the gyro goes backwards, then make the gain negative.
Kettering Motorsports
AD22305 Gyroscope Data Sheet? Hadi379 General Forum 6 09-01-2009 11:41
No Gyroscope in KOP???? Sunshine General Forum 3 04-01-2009 15:50
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Gyroscope saturation? Tom Line Programming 32 14-01-2008 12:07
Gyroscope Orentation Decay D.Viddy Programming 12 13-01-2003 14:43
